CLI daemons for MOS
    jalla
    Posts: 57 from 2004/10/4
    Are there any easy ways to connect to a remote MorphOS machine via network and access CLI from a terminal client ? Which daemons should I run from MOS side ? Anybody?
    Pegasos II/G4/512MB/Radeon9200
  • »20.04.12 - 14:57
    Lizard
    Posts: 34 from 2004/4/27
    I think there are 2 options available:
    Install Telser from aminet as a telnetd so you can telnet from a remote machine to your Morphos machine.
    (the keyfile for telser has also been uploaded to aminet.)
    But I wouldn't use this option over the internet, since telnet is a plain text protocol with no security.
    Another option is to install VNC Server.
    A third option could be installing a ssh server, but I don't know if that was released for Morphos.
  • »20.04.12 - 17:14
    Posts: 2213 from 2003/2/24
    I just tried telnetd2_0 from Aminet quickly and it seems to work fine under MorphOS too. I can log in and run commands like dir, list, type at least...
  • »21.04.12 - 04:31
    CountRaven
    Posts: 566 from 2007/12/10
    VNCServer also works great and it is very stable.
    This is my Pegasos 1 machine controller through my PowerMac G5.
    http://www.amigaplanet.gr/forum/download/file.php?id=552&mode=view
  • »22.04.12 - 08:16
    Posts: 647 from 2004/4/15
    A sshd for morphOs would be great!
  • »22.04.12 - 09:38
