PowerSdl 15
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello, i'm just trying to find Powersdl version 15 that was mentioned in the forum, but the link is broken, and searching on google gives no info. Tried on aminet, but only the 14 is available. Anyone?
    Thanks in advance!!!
  • »10.04.12 - 10:48
    Posts: 12572 from 2003/5/22
    > the link is broken
    Works here:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7461&forum=9&start=11
  • »10.04.12 - 11:30
    _ThEcRoW
    But this is only the powersdl.library file. On the 14 release it was contained along several libraries. Are the version 15 only available in this library file?.
  • »10.04.12 - 12:02
    AFAIK yes. It's not at release level anyway.
  • »10.04.12 - 12:36
    Posts: 1521 from 2003/2/24
    I recommend using V14 still because V15 is not finished. (Yes I should start working on it again...)
  • »10.04.12 - 16:11
    _ThEcRoW
    Ok, no prob, just went back to 14 to avoid possible crashes.
    Thanks!
  • »12.04.12 - 21:00
