About Vice latest release
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello guys, i'm still getting my new installation of morphos stuffed with the apps i used to have, and today i installed vice, but it gives me a strange error, and i recall that vice was working in my last morphos system.
    The error in question is the following: x64 illegal instruction.
    Note that the x64 is the exe for c64, not get confused with x86 64 stuff.
  • »11.04.12 - 11:03
    defender
    Posts: 249 from 2011/4/24
    _ThEcRoW,
    I just downloaded the version 2.2 from
    http://www.zimmers.net/anonftp/pub/cbm/crossplatform/emulators/VICE/VICE-MorphOS-2.2.tar.gz
    extracted to ram ... x64 starts in a Window.
    So it seems there is no fault in the program.
    Snoopium Log:
    [1] [x64] [Open] [Ram Disk:VICE-MorphOS-2.2/fliplist-C64.vfl] [Lesen] [Fehlgeschlagen]
    [2] [x64] [Open] [Ram Disk:VICE-MorphOS-2.2/vice.ini] [Lesen] [Fehlgeschlagen]
    [3] [x64] [Open] [muidebug] [Lesen] [Fehlgeschlagen]
    [4] [ahi.device Unit Process] [Open] [AHIemu10kxRecordBufferSize.1] [Lesen] [Fehlgeschlagen]
    [5] [ahi.device Unit Process] [Open] [AHIemu10kxRecordBufferSize] [Lesen] [Fehlgeschlagen]
    greets
    defender
    [ Editiert durch defender 11.04.2012 - 14:52 ]
  • »11.04.12 - 13:48
    Posts: 12572 from 2003/5/22
    Have a look there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8060&forum=9
    So defender seems to be right that the only solution is to use the previous version.
  • »11.04.12 - 16:39
    _ThEcRoW
    Thanks. Downloaded the 2.2 version and works ok.
  • »12.04.12 - 11:49
