ShowNetStatus
    djrikki
    Posts: 16 from 2012/3/18
    Quick questions, I need to be able to return the Local IP Address of the machine, under AmigaOS I call ShowNetStatus and scrap it from the second line.
    1) Is there an equivalent under MorphOS which comes as standard?
    2) Where is it located? Complete path to executable please.
    3) Please dump default output or provide syntax that dumps out the Local IP Address, the entire dump.
  • »18.03.12 - 15:37
    Posts: 1386 from 2010/1/6
    Mossys:c/ifconfig could be what you need....... (ifconfig -h shows options)
  • »18.03.12 - 15:44
    djrikki
    I don't have a MorphOS machine to try this so I need a working example with dump of the CLI output.
  • »18.03.12 - 15:50
    Krashan
    Posts: 1107 from 2003/6/11
    You can get one for $50 ;-). And free version of MorphOS is enough to try all the things you ask in numerous posts.
  • »18.03.12 - 16:35
    boot_wb
    Posts: 874 from 2007/4/9
    djrikki,
    I have a spare G4 Powermac (dual 1GHz MDD) lying around unused.
    It doesn't have a license key for MorphOS, so would be limited to the 30-minutes timeout, but you're welcome to borrow it for development if you want, since you're just across the bridge from me.
    I'll even set up a couple of vanilla partitions for you.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »18.03.12 - 17:15
    boot_wb
    djrikki,
    ifconfig
    sys:morphos/c, but as this is added to path during startup-sequence, you can just call the executable without the path:to/file.
    Don't know about default output, but here's the result from my mac-mini running 2.7:
    Ram Disk:> ifconfig
    lo0: flags=c9<UP,LOOPBACK,RUNNING,NOARP> MTU=16436
    inet 127.0.0.1 netmask ff000000
    Hardware type: Loopback
    eth0: flags=4863<UP,BROADCAST,NOTRAILERS,RUNNING,SIMPLEX,SANA> MTU=1500
    inet 192.168.0.102 netmask ffffff00 broadcast 192.168.0.255
    Hardware type: Ethernet, address: 0:14:51:2d:80:fe
    Use "ifconfig -h" for usage.
  • »18.03.12 - 17:26
    djrikki
    Might have to take you up on that one, no license key is fine.
    So when is best for you? Afternoons? Or evenings only. PM your details and we'll talk it through in private.
  • »19.03.12 - 21:25
