IdeTool
    djrikki
    Posts: 16 from 2012/3/18
    Quick question, I need to determine the CPU Installed.
    I am looking for equalivant to idetool -c, in AmigaOS I simply scrap the first line removing hyphens.
    1) Is there an equivalent? It must come as standard.
    2) If yes where is it located, complete path to executable required.
    3) Syntax if required.
    4) A complete dump of the CLI Output so I can scrap the information.
    Thanks agaiN!
  • »18.03.12 - 15:41
    Posts: 1390 from 2010/1/6
    Don't know idetool, but DOS-Command CPU shows all system-informaton, including CPU-Type......
  • »18.03.12 - 15:48
    pampers
    Posts: 1073 from 2009/2/26
    Just type cpu in shell window :)
    Have a look into MOSSYS:c/
    MorphOS 3.x
  • »18.03.12 - 15:49
    djrikki
    Same as on other thread, I don't have access to a MorphOS machine so I need someone to type CPU and paste the whole text in here so I can see the exact output.
  • »18.03.12 - 15:52
    Korni
    Posts: 473 from 2006/2/23
    Ram Disk:> ShowConfig >nnn | Search NONUM nnn PROCESSOR
    PROCESSOR: 7447A (G4) (V1.2) 1667MHz (FSB 166MHz)
  • »18.03.12 - 16:08
    pampers
    Can you open one thread with ur questions?
    MorphOS 3.x
  • »18.03.12 - 17:42
    Posts: 1521 from 2003/2/24
    Ram Disk:> cpu
    System: PowerMac10,2
    Machine: 0x1
    PageSize: 4096 Bytes
    CPUCount: 1
    CPU0: 7447A (G4) Version 32771 Revision 261
    CPU0: CPUClock 1499999994 BusClock 166005898
    CPU0: FPU Unit exists
    CPU0: Altivec Unit exists
    CPU0: Performance Monitor Unit exists
    CPU0: DataStream Unit exists
    CPU0: ReservationSize 32
    CPU0: Ticks 4
    CPU0: CacheL1Type 0x0
    CPU0: CacheL1Flags 0x1000F
    CPU0: ICacheL1Size 32768
    CPU0: ICacheL1Lines 1024
    CPU0: ICacheL1LineSize 32
    CPU0: DCacheL1Size 32768
    CPU0: DCacheL1Lines 1024
    CPU0: DCacheL1LineSize 32
    CPU0: CacheL2Type 0x0
    CPU0: CacheL2Flags 0x1001D
    CPU0: ICacheL2Size 524288
    CPU0: ICacheL2Lines 0
    CPU0: ICacheL2LineSize 0
    CPU0: DCacheL2Size 524288
    CPU0: DCacheL2Lines 0
    CPU0: DCacheL2LineSize 0
  • »19.03.12 - 04:08
