Posts: 117 from 2003/12/28
@Mithalas
No, you don't have to update the SANA II drivers.
Which version of AmiTCP are you using?
If it is 4.0 demo then you are going to have to edit some script files. In the installer choose ethernet and the first ethernet device(a2065 I think) don't worry that this is not the right device, you edit the config files later.
Say yes to adding assigns, and no to start at boot.
Ok, edit the file 'AmiTCP: db/interfaces and add the line:
vrhine DEV=DEV:Networks/via_rhinepci.device
continued
Ask Dr. Stupid,
Dear Dr. Stupid,
Why do we have to go to school?
That's a very good question. It's becuse your parents are
ALIENS!!! When your at school they shed there human skins and
breathe drier lint! hahahaha!
