can't log in to google
    gothor
    Posts: 35 from 2011/4/6
    When i use OWB V. 1.16 i cant login. I get an error 60... it look like a certificat error. Has someone the same message?
    Thanks for help!
  • »20.02.12 - 15:15
    xyphoid
    Posts: 870 from 2008/7/11
    haven't noticed this, and I use it a bit. I used the ver1.16 package by it self not combined with my older version folder, as I am still testing
    it out.
  • »20.02.12 - 17:04
    defender
    Posts: 249 from 2011/4/24
    just a short test - no login problems at google-docs, google-mail does not work good since the newest
    gui update. But I saw no login problems.
    greets defender
  • »20.02.12 - 19:25
    redrumloa
    Posts: 1424 from 2003/4/13
    What date is your clock?
  • »20.02.12 - 21:49
    pampers
    Posts: 1073 from 2009/2/26
    Hi
    Did you tried to Ingore SSL Errors in OWB's prefs?
    MorphOS 3.x
  • »21.02.12 - 09:37
    gothor
    Thanks all for help.. after using the option ignore ssl error's it work's again ... thanks
    gothor
    [ Editiert durch gothor 04.03.2012 - 15:57 ]
  • »04.03.12 - 13:55
    Simon
    Posts: 809 from 2008/7/6
    I only have problems with this when for some reason date and/or time are wrong
  • »04.03.12 - 13:56
    gothor
    no, my time and my date are correct.
  • »04.03.12 - 13:59
