Shell output after a search to be opened via the mouse! Doub
    osco
    Posts: 680 from 2009/10/21
    Short: DoubleClick files from the shell (Opus5)
    Author: robert@genpart.demon.co.uk (Robert Wilson)
    Uploader: robert genpart demon co uk (Robert Wilson)
    Type: biz/dopus
    Version: 1.0
    Architecture: generic
    One of the many wonderful things about Directory Opus is the ability to
    Double Click on any file and it will be opened or viewed with the best
    application for the job.
    There were many times when I wanted to do this from the shell, so maybe I
    could use multiview...? Okay if I just want to view a picture, read a bit
    of text or play a sound, but beyond that it's pretty useless.
    This is when Dopus Double Click was born allowing easy opening of any file
    from the shell.
  • »03.03.12 - 11:05
    Henes
    Posts: 507 from 2003/6/14
    You can try c:open which is linked to Ambient's MIME system.
    f.e. "c:open work:my.jpg"
  • »03.03.12 - 14:09
    osco
    Shell output from the "search" command
    System:tamp/201202100926wv600en.txt
    System:tamp/201202091323wv600en.txt
    System:tamp/201201280926wv600en.txt
    System:tamp/201201071120wv600en.txt
    System:tamp/201112290954wv600en.txt
    System:tamp/201202251221wv600en.txt
    System:tamp/201112231309wv600en.txt
    System:tamp/201202221120wv600en.txt
    System:tamp/201202220956wv600en.txt
    System:tamp/201201131422wv600en.txt
    The above list is copied from from the consol window
    and pasted into Morph Editor
    where after two replace from the Editor menu
    the output below is copied into a shell
    open system:tamp/201202100926wv600en.pdf
    open system:tamp/201202091323wv600en.pdf
    open system:tamp/201201280926wv600en.pdf
    open system:tamp/201201071120wv600en.pdf
    open system:tamp/201112290954wv600en.pdf
    open system:tamp/201202251221wv600en.pdf
    open system:tamp/201112231309wv600en.pdf
    open system:tamp/201202221120wv600en.pdf
    open system:tamp/201202220956wv600en.pdf
    All the now pdf files are opened
    :-D
    How to get rid of CLI and make it mouse driven
    Arexx script any short cuts :-D
  • »03.03.12 - 15:19
