Viewing Amigaguide documents
    winterhunter
    Posts: 204 from 2005/10/13
    Which program do you use to view amigaguide hypertexts?
    I've tried searching Aminet, but I found 543 matching packages...
    Thanks!
  • »20.06.07 - 11:40
    hooligan
    Posts: 1948 from 2003/2/23
    PowerGuide
  • »20.06.07 - 13:04
    imax
    Posts: 41 from 2004/9/20
    Thanks!
    I use "DoubleClick" ;-)
    Before i copy amigaguide.datatype from AmigaOS disk.
  • »21.06.07 - 07:15
    winterhunter
    "Doubleclick" is my favorite app :-D
    I will copy the amigaguide datatype files from my AOS 3.5 CD (the AOS 3.1 versions of the datatype).
    Thanks a lot!
  • »21.06.07 - 08:27
  • HAK
    Posts: 227 from 2003/2/24
    Erm, what's so bad about MultiView which is part of MOS?
    Of course, you have to install the amigaguide datatype/library from an older AOS version before, but as you have to do it for "Doubleclick" anyway.
    Bye HAK
  • »21.06.07 - 20:57
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    I'd recommend PowerGuide, too. The nice thing is, that you can do text searches within the document.
    Nonetheless copying amigaguide.library still make sense as without the context sensitive help system of (mostly MUI) applications doesn't work.
  • »22.06.07 - 09:55
    osco
    Posts: 680 from 2009/10/20
    How do you "hyperize" output from an Arexx script? Going to Aminet to see about Doublecick. My son has this thing about the mouse and an aversion to CLI :-D
  • »02.03.12 - 09:40
    Posts: 2581 from 2003/2/24
    Typical answer to typical osco-post:
    W T F ? ? ! ! ! ?
  • »02.03.12 - 13:35
    osco
    KIronos  :-D
    Heading to the manual but this PowerBook needs 3.0
  • »02.03.12 - 17:06
