Favicon in Odyssey bookmarks
    Posts: 2728 from 2003/2/24
    I just noticed that when you enter websites *manually* into the Odyssey bookmark editor (instead of adding the page you are currently viewing), the Favicons of the site will never appear, not even when you visit the site later on. On other browsers, the favicons doesn't appear in the bookmark list directly after entering a bookmark manually either, but as soon as you visit the site afterwards, it gets added. I think this would be a cool bahavior in Odyssey as well! :-)
  • »24.01.12 - 10:19
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    This works as you want in Odyssey too, after a restart, but it won't work if some redirections are involved, so better make sure you enter exactly the final URL (including slashes).
    Making it work at runtime should be doable as well, just needs some additional notification on the address itself (which is just empty when added manually);
    [ Edited by Fab 24.01.2012 - 14:14 ]
  • »24.01.12 - 12:39
