Somehow USB is hosed...
    TheMagicM
    Posts: 1218 from 2003/6/17
    So I was overjoyed with trying out MAME on MorphOS and somehow I hosed USB.
    At the time I was playing around with giggledisk, but that uses usbscsi device. Being that I didnt have the USB drive hooked up, upon boot it would complain and tell me that it cannot find it, I had to assign, retry, deny, cancel requestor. At that time the mouse pointer was moveable. As soon as I hit cancel, the system booted up and USB mouse/kb does not work.
    I booted from MorphOS 2.7 CD, went into DEVS/Dosdrivers and deleted the mountlist file (usbscsi0) and that requestor didnt pop up on reboot. So it boots and nothing works. The clock is still going though. When I put the MorphOS cd in, the icon does not appear.
    Maybe I hosed my USB config? Can I delete that? I've already checked WBStartup (I didnt add anything), startup-sequence and user-startup was not modified.
    Any help appreciated.
    EDIT: I'm just going to do an UPDATE installation.
    EDIT #2: The UPDATE installation didnt fix it. lol
    [ Edited by TheMagicM 29.12.2011 - 20:15 ]
  • »30.12.11 - 03:10
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    I'm not exactly sure what happens here, but you might want to delete thehosedsystem:prefs/env-archive/sys/poseidon.prefs (or put the original one).
    [ Edited by Fab 30.12.2011 - 02:26 ]
  • »30.12.11 - 03:25
    TheMagicM
    @Fab:
    dude...you're the freakin man! THANK YOU!!!!!!
  • »30.12.11 - 03:32
