Video Converting
    cyb3rjunki3
    Posts: 4 from 2011/12/15
    what is the closest thing to something like vso convertxtodvd for Morph OS,
    I want more than one video file and selection menu for home made dvd's
  • »15.12.11 - 15:19
    Posts: 12572 from 2003/5/22
    I never used it myself but I believe DVD-Engine is supposed to be able to create DVD menus. There's also a more recent program by the same author called BlueHD which may also be able to do that. Both programs are GUIs for the dvdauthor command line tool.
  • »15.12.11 - 15:32
    cyb3rjunki3
    thank you, i will look into these ;)
  • »15.12.11 - 17:34
    XDelusion
    Posts: 602 from 2010/10/27
    Where can those programs be downloaded?
  • »15.12.11 - 19:26
    Click on the highlighted words. The reason they're in bold is that those are actually hyperlinks.
  • »15.12.11 - 19:36
    XDelusion
    Aghh, the lack of under lines threw me off. Thankx!
    [ Edited by XDelusion 15.12.2011 - 15:56 ]
  • »15.12.11 - 19:56
    xyphoid
    Posts: 870 from 2008/7/11
    I haven't had menues on blueHd, just the conversion to dvd format, which doesn't play on all players.
    (magnovox eg.)
  • »15.12.11 - 19:56
    connor
    Posts: 650 from 2007/7/29
    Did you write a mail to the author? Maybe he can give an update.
  • »15.12.11 - 20:39
    a bit off topic, but related, so forgive me this tangent.
    What video input devices do any of you use to move your analog video sources into the digital realm using MorphOS?
    I was thinking of perhaps buying an "EasyCap" USB2.0 device which can be found for as little as $6.30 U.S. dollars online at Amazon.com. It is not clear if they have Mac drivers, but the same (or similar) device is available for $22 that shows it has MacOSX support. It might be a different model from the same company. It listed support for MacOSX 10.4.7, so the one I found was probably an older NOS item.
    Not sure Poseidon drivers cover USB video capture devices. I will need to check the Poseidon docs.
    [ Edited by amigadave 16.12.2011 - 19:29 ]
  • »17.12.11 - 02:28
