magicalink, needing Help
    sergius
    Posts: 47 from 2005/12/6
    I would like to use magicalink for some work and I have a strange thing:
    When I draw a text box and try to edit the text on object properties, the text is unchanged and it displays allways (null)  :-(
    Is this a bug or something I dont understood?
    thx
  • »21.11.11 - 17:31
    Posts: 1351 from 2004/2/8
    How do you do it?
    It should go like that:
    1. Draw a text box
    2. Select "Tools" and then "Edit.T."
    3. Change the defauld "Text" in new texteditor window
  • »21.11.11 - 17:46
    sergius
    koszer,
    1. Draw a text box
    This is the way I do :-(
    [ Edited by sergius 21.11.2011 - 20:07 ]
  • »21.11.11 - 18:06
  • rms
    rms
    Posts: 606 from 2004/11/27
    I have the same problem here, it seems that it can't find the fonts... because when clicking on the font selector no fonts are shown...
  • »22.11.11 - 05:26
    serge
    Posts: 725 from 2003/2/20
    rms,
    Right, if I try to underline or bold etc, the (null) is affected by this parameters like if it were the text.
    This makes me thinking that the text space is empty and replaced by (null)
  • »22.11.11 - 12:16
    serge
    I have found the solution :
    Ther's one file to delete :
    sys:Prefs/Env-Archive/MUI/MAGICALINK.cfg
    If there's always troubles, delete this
    sys:Prefs/Env-Archive/MUI/MAGICALINK.1.prefs
    A reset is needed to empty env: ;-)
    [ Edited by serge 04.12.2011 - 16:12 ]
  • »04.12.11 - 07:13
    Posts: 12500 from 2003/5/22
    Really? I think applying the changes done to ENVARC: to ENV: as well should suffice.
  • »04.12.11 - 15:13
    serge
    Andreas_Wolf,
    Are you sure?
    I never saw a file deleted by hand on env-archive beeing automaticaly deleted on ram:env/ without a reset.
    You should delete it yourself by hand, but a reset is easier for most people.
    [ Edited by serge 04.12.2011 - 20:12 ]
  • »04.12.11 - 18:11
    > Are you sure? I never saw a file deleted by hand on env-archive beeing
    I didn't say anything about "automatically".
    Yes, that's what I meant.
    Yes, but without reset it's faster, even with the minimal reboot time of MorphOS.
  • »04.12.11 - 19:03
