Posts: 777 from 2011/11/30
@Count
Bro, you can forget oBOR for all amiga-like ng systems :(
Same performance issues (extreme loading times, lock ups, slow fps rate) can be found on both MOS and AOS alike (on AOS I had also usb drop outs on my joysticks but that could be caused by AmigaInput).
Furthermore the engine isn't that lightweight, it nearly crashes my Core2Duo 2.4Ghz (on Vista and 7) while playing some of its mods (e.g. Rhythm of Destruction, which is awesome btw).
The only solution for the time being is to play it on a >1.5Ghz x86 / Win combo (console versions don't support the whole list of mods).
