MorphOS Developer
Posts: 662 from 2005/2/9
version 0.14
http://aminet.net/text/show/xmlviewer.lha
- Cliboard support (0.12)
Context menu with Cut Copy was added.
(items <subtrees> under mouse pointer are converted to
plain xml text files)
- Shortcuts & Paste (0.14)
(active item - command+c, command+v, command+x)
+ Overall fixes
TODO:
- Edit mode
- Comments support
- Locale
- Drag&Drop
»08.03.09 - 15:55
MorphOS Developer
version 0.16
- More fixes (0.15)
- Locales, comments (0.16)
TODO:
- Edit mode
- Drag&Drop
http://brain.umcs.lublin.pl/~rzookol/download/xmlviewer.lha
»28.05.09 - 19:47
Posts: 94 from 2003/7/29
Is it possible to use plot.mcc directly from Muibase? I have to start 'test' no as first stap and use 'open' for my database. It works fine, but the possibility to use the data right from Muibase would be great.....
Regards Tom
»30.11.11 - 14:32
