Docs missing in euae archive
    redrumloa
    Posts: 1424 from 2003/4/13
    The readme says "documentation is a work-in-progress, please see Docs directory". One problem, there is no Docs directory. Google is not as helpful as I'd like.
    I got EUAE working, but I would like to tweak it. Hard to tweak settings without docs.
  • »27.11.11 - 23:07
    redrumloa
    I found this which will probably help me. I'd still like to see MorphOS specific docs, if they exist, as there will likely be some difference.
  • »27.11.11 - 23:14
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    There shouldn't be any difference to the original uae options, except for the addition of overlay output, that is done with amiga.use_overlay= true|false.
    And you can forget about network bsd emulation and JIT at least. The options will be accepted, but that's it. :)
    [ Edited by Fab 27.11.2011 - 23:34 ]
  • »27.11.11 - 23:32
