Posts: 525 from 2009/9/8
Rajinder wrote:
@Divinity
Thx, that works a treat...
BUT
This will sounds a bit lame, but how do i make an .exe file
can i also put it in wbstartup so it auto loads my server?..
yes, sure, use iconx to create the "exe" to have the auto mount
then you can make CTRL+C to close the "exe" to have the auto unmount of the volume
