AminetRadio, Why do you hate me?
    XDelusion
    Posts: 602 from 2010/10/27
    So I've been setting up my MorphOS install on my eMac again, but for some reason, when ever I click on Aminet Radio, nothing happens. When I double click it again, the bar at the top of the screen flashes red for a second, then again nothing.
    The only change I notice is that this prevents me from being able to soft boot.
    I ran Snoopium, here's the log:
    [1] [ramlib] [Open] [MOSSYS:LIBS/mathieeesingbas.library.elf] [Read] [Fail]
    [2] [ramlib] [Open] [MOSSYS:LIBS/mathieeesingbas.library.elf] [Read] [Fail]
    [3] [ramlib] [Load] [MOSSYS:LIBS/mathieeesingbas.library.elf] [] [Fail]
    [4] [AmiNetRadio] [ToolType] [URL] [] [Fail]
    [5] [AmiNetRadio] [ToolType] [DECODERPRI] [] [Fail]
    [6] [AmiNetRadio] [ToolType] [PRI] [] [Fail]
    [7] [AmiNetRadio] [ToolType] [NOSTARTWINDOW] [] [Fail]
    [8] [ramlib] [Open] [MOSSYS:LIBS/render.library.elf] [Read] [Fail]
    [9] [ramlib] [Open] [MOSSYS:LIBS/render.library.elf] [Read] [Fail]
    [10] [ramlib] [Load] [MOSSYS:LIBS/render.library.elf] [] [Fail]
    [11] [ramlib] [Open] [MOSSYS:LIBS/guigfx.library.elf] [Read] [Fail]
    [12] [ramlib] [Open] [MOSSYS:LIBS/guigfx.library.elf] [Read] [Fail]
    [13] [ramlib] [Load] [MOSSYS:LIBS/guigfx.library.elf] [] [Fail]
    [14] [AmiNetRadio] [Open] [ENV:guigfx/autoditherthreshold] [Read] [Fail]
    [15] [AmiNetRadio] [Open] [ENVARC:guigfx/autoditherthreshold] [Read] [Fail]
    [16] [AmiNetRadio] [Open] [ENV:guigfx/usescalepixelarray] [Read] [Fail]
    [17] [AmiNetRadio] [Open] [ENVARC:guigfx/usescalepixelarray] [Read] [Fail]
    [18] [AmiNetRadio] [Open] [ENV:guigfx/usewpa8] [Read] [Fail]
    [19] [AmiNetRadio] [Open] [ENVARC:guigfx/usewpa8] [Read] [Fail]
    [20] [ramlib] [Open] [MOSSYS:LIBS/HotkeyString.mcc.elf] [Read] [Fail]
    [21] [ramlib] [Open] [MOSSYS:LIBS/HotkeyString.mcc.elf] [Read] [Fail]
    [22] [ramlib] [Load] [MOSSYS:LIBS/HotkeyString.mcc.elf] [] [Fail]
    [23] [ramlib] [Open] [MOSSYS:LIBS/HotkeyString.mcc] [Read] [Fail]
    [24] [ramlib] [Open] [MOSSYS:LIBS/HotkeyString.mcc] [Read] [Fail]
    [25] [ramlib] [Load] [MOSSYS:LIBS/HotkeyString.mcc] [] [Fail]
    [26] [ramlib] [Open] [LIBS:HotkeyString.mcc.elf] [Read] [Fail]
    [27] [ramlib] [Open] [LIBS:HotkeyString.mcc.elf] [Read] [Fail]
    [28] [ramlib] [Load] [LIBS:HotkeyString.mcc.elf] [] [Fail]
    [29] [ramlib] [Open] [HotkeyString.mcc.elf] [Read] [Fail]
    [30] [ramlib] [Open] [HotkeyString.mcc.elf] [Read] [Fail]
    [31] [ramlib] [Load] [HotkeyString.mcc.elf] [] [Fail]
    [32] [ramlib] [Open] [LIBS:HotkeyString.mcc] [Read] [Fail]
    [33] [ramlib] [Open] [LIBS:HotkeyString.mcc] [Read] [Fail]
    [34] [ramlib] [Load] [LIBS:HotkeyString.mcc] [] [Fail]
    [35] [ramlib] [Open] [HotkeyString.mcc] [Read] [Fail]
    [36] [ramlib] [Open] [HotkeyString.mcc] [Read] [Fail]
    [37] [ramlib] [Load] [HotkeyString.mcc] [] [Fail]
    [38] [ramlib] [Open] [PROGDIR:LIBS/HotkeyString.mcc.elf] [Read] [Fail]
    [39] [ramlib] [Open] [PROGDIR:LIBS/HotkeyString.mcc.elf] [Read] [Fail]
    [40] [ramlib] [Load] [PROGDIR:LIBS/HotkeyString.mcc.elf] [] [Fail]
    [41] [ramlib] [Open] [PROGDIR:LIBS/HotkeyString.mcc] [Read] [Fail]
    [42] [ramlib] [Open] [PROGDIR:LIBS/HotkeyString.mcc] [Read] [Fail]
    [43] [ramlib] [Load] [PROGDIR:LIBS/HotkeyString.mcc] [] [Fail]
    [44] [ramlib] [Open] [MOSSYS:LIBS/mui/HotkeyString.mcc.elf] [Read] [Fail]
    [45] [ramlib] [Open] [MOSSYS:LIBS/mui/HotkeyString.mcc.elf] [Read] [Fail]
    [46] [ramlib] [Load] [MOSSYS:LIBS/mui/HotkeyString.mcc.elf] [] [Fail]
    [47] [ramlib] [Open] [MOSSYS:LIBS/mui/HotkeyString.mcc] [Read] [Fail]
    [48] [ramlib] [Open] [MOSSYS:LIBS/mui/HotkeyString.mcc] [Read] [Fail]
    [49] [ramlib] [Load] [MOSSYS:LIBS/mui/HotkeyString.mcc] [] [Fail]
    [50] [ramlib] [Open] [LIBS:mui/HotkeyString.mcc.elf] [Read] [Fail]
    [51] [ramlib] [Open] [LIBS:mui/HotkeyString.mcc.elf] [Read] [Fail]
    [52] [ramlib] [Load] [LIBS:mui/HotkeyString.mcc.elf] [] [Fail]
    [53] [ramlib] [Open] [mui/HotkeyString.mcc.elf] [Read] [Fail]
    [54] [ramlib] [Open] [mui/HotkeyString.mcc.elf] [Read] [Fail]
    [55] [ramlib] [Load] [mui/HotkeyString.mcc.elf] [] [Fail]
    [56] [AmiNetRadio] [Open] [MUISTRINGCLASS] [Read] [Fail]
    [57] [ramlib] [Open] [MOSSYS:LIBS/BetterString.mcc.elf] [Read] [Fail]
    [58] [ramlib] [Open] [MOSSYS:LIBS/BetterString.mcc.elf] [Read] [Fail]
    [59] [ramlib] [Load] [MOSSYS:LIBS/BetterString.mcc.elf] [] [Fail]
    [60] [ramlib] [Open] [MOSSYS:LIBS/BetterString.mcc] [Read] [Fail]
    [61] [ramlib] [Open] [MOSSYS:LIBS/BetterString.mcc] [Read] [Fail]
    [62] [ramlib] [Load] [MOSSYS:LIBS/BetterString.mcc] [] [Fail]
    [63] [ramlib] [Open] [LIBS:BetterString.mcc.elf] [Read] [Fail]
    [64] [ramlib] [Open] [LIBS:BetterString.mcc.elf] [Read] [Fail]
    [65] [ramlib] [Load] [LIBS:BetterString.mcc.elf] [] [Fail]
    [66] [ramlib] [Open] [BetterString.mcc.elf] [Read] [Fail]
    [67] [ramlib] [Open] [BetterString.mcc.elf] [Read] [Fail]
    [68] [ramlib] [Load] [BetterString.mcc.elf] [] [Fail]
    [69] [ramlib] [Open] [LIBS:BetterString.mcc] [Read] [Fail]
    [70] [ramlib] [Open] [LIBS:BetterString.mcc] [Read] [Fail]
    [71] [ramlib] [Load] [LIBS:BetterString.mcc] [] [Fail]
    [72] [ramlib] [Open] [BetterString.mcc] [Read] [Fail]
    [73] [ramlib] [Open] [BetterString.mcc] [Read] [Fail]
    [74] [ramlib] [Load] [BetterString.mcc] [] [Fail]
    [75] [ramlib] [Open] [PROGDIR:LIBS/BetterString.mcc.elf] [Read] [Fail]
    [76] [ramlib] [Open] [PROGDIR:LIBS/BetterString.mcc.elf] [Read] [Fail]
    [77] [ramlib] [Load] [PROGDIR:LIBS/BetterString.mcc.elf] [] [Fail]
    [78] [ramlib] [Open] [PROGDIR:LIBS/BetterString.mcc] [Read] [Fail]
    [79] [ramlib] [Open] [PROGDIR:LIBS/BetterString.mcc] [Read] [Fail]
    [80] [ramlib] [Load] [PROGDIR:LIBS/BetterString.mcc] [] [Fail]
    [81] [ramlib] [Open] [MOSSYS:LIBS/mui/BetterString.mcc.elf] [Read] [Fail]
    [82] [ramlib] [Open] [MOSSYS:LIBS/mui/BetterString.mcc.elf] [Read] [Fail]
    [83] [ramlib] [Load] [MOSSYS:LIBS/mui/BetterString.mcc.elf] [] [Fail]
    [84] [ramlib] [Open] [MOSSYS:LIBS/mui/BetterString.mcc] [Read] [Fail]
    [85] [ramlib] [Open] [MOSSYS:LIBS/mui/BetterString.mcc] [Read] [Fail]
    [86] [ramlib] [Load] [MOSSYS:LIBS/mui/BetterString.mcc] [] [Fail]
    [87] [ramlib] [Open] [LIBS:mui/BetterString.mcc.elf] [Read] [Fail]
    [88] [ramlib] [Open] [LIBS:mui/BetterString.mcc.elf] [Read] [Fail]
    [89] [ramlib] [Load] [LIBS:mui/BetterString.mcc.elf] [] [Fail]
    [90] [ramlib] [Open] [mui/BetterString.mcc.elf] [Read] [Fail]
    [91] [ramlib] [Open] [mui/BetterString.mcc.elf] [Read] [Fail]
    [92] [ramlib] [Load] [mui/BetterString.mcc.elf] [] [Fail]
    [93] [ramlib] [Open] [LIBS:mui/BetterString.mcc] [Read] [Fail]
    [94] [ramlib] [Open] [LIBS:mui/BetterString.mcc] [Read] [Fail]
    [95] [ramlib] [Load] [LIBS:mui/BetterString.mcc] [] [Fail]
    [96] [ramlib] [Open] [mui/BetterString.mcc] [Read] [Fail]
    [97] [ramlib] [Open] [mui/BetterString.mcc] [Read] [Fail]
    [98] [ramlib] [Load] [mui/BetterString.mcc] [] [Fail]
    [99] [ramlib] [Open] [PROGDIR:LIBS/mui/BetterString.mcc.elf] [Read] [Fail]
    [100] [ramlib] [Open] [PROGDIR:LIBS/mui/BetterString.mcc.elf] [Read] [Fail]
    [101] [ramlib] [Load] [PROGDIR:LIBS/mui/BetterString.mcc.elf] [] [Fail]
    [102] [ramlib] [Open] [PROGDIR:LIBS/mui/BetterString.mcc] [Read] [Fail]
    [103] [ramlib] [Open] [PROGDIR:LIBS/mui/BetterString.mcc] [Read] [Fail]
    [104] [ramlib] [Load] [PROGDIR:LIBS/mui/BetterString.mcc] [] [Fail]
    [105] [ramlib] [Open] [MOSSYS:LIBS/BetterString.mcc.elf] [Read] [Fail]
    [106] [ramlib] [Open] [MOSSYS:LIBS/BetterString.mcc.elf] [Read] [Fail]
    [107] [ramlib] [Load] [MOSSYS:LIBS/BetterString.mcc.elf] [] [Fail]
    [108] [ramlib] [Open] [MOSSYS:LIBS/BetterString.mcc] [Read] [Fail]
    [109] [ramlib] [Open] [MOSSYS:LIBS/BetterString.mcc] [Read] [Fail]
    [110] [ramlib] [Load] [MOSSYS:LIBS/BetterString.mcc] [] [Fail]
    [111] [ramlib] [Open] [LIBS:BetterString.mcc.elf] [Read] [Fail]
    [112] [ramlib] [Open] [LIBS:BetterString.mcc.elf] [Read] [Fail]
    [113] [ramlib] [Load] [LIBS:BetterString.mcc.elf] [] [Fail]
    [114] [ramlib] [Open] [BetterString.mcc.elf] [Read] [Fail]
    [115] [ramlib] [Open] [BetterString.mcc.elf] [Read] [Fail]
    [116] [ramlib] [Load] [BetterString.mcc.elf] [] [Fail]
    [117] [ramlib] [Open] [LIBS:BetterString.mcc] [Read] [Fail]
    [118] [ramlib] [Open] [LIBS:BetterString.mcc] [Read] [Fail]
    [119] [ramlib] [Load] [LIBS:BetterString.mcc] [] [Fail]
    [120] [ramlib] [Open] [BetterString.mcc] [Read] [Fail]
    [121] [ramlib] [Open] [BetterString.mcc] [Read] [Fail]
    [122] [ramlib] [Load] [BetterString.mcc] [] [Fail]
    [123] [ramlib] [Open] [PROGDIR:LIBS/BetterString.mcc.elf] [Read] [Fail]
    [124] [ramlib] [Open] [PROGDIR:LIBS/BetterString.mcc.elf] [Read] [Fail]
    [125] [ramlib] [Load] [PROGDIR:LIBS/BetterString.mcc.elf] [] [Fail]
    [126] [ramlib] [Open] [PROGDIR:LIBS/BetterString.mcc] [Read] [Fail]
    [127] [ramlib] [Open] [PROGDIR:LIBS/BetterString.mcc] [Read] [Fail]
    [128] [ramlib] [Load] [PROGDIR:LIBS/BetterString.mcc] [] [Fail]
    [129] [ramlib] [Open] [PROGDIR:mui/BetterString.mcc.elf] [Read] [Fail]
    [130] [ramlib] [Open] [PROGDIR:mui/BetterString.mcc.elf] [Read] [Fail]
    [131] [ramlib] [Load] [PROGDIR:mui/BetterString.mcc.elf] [] [Fail]
    [132] [ramlib] [Open] [PROGDIR:mui/BetterString.mcc] [Read] [Fail]
    [133] [ramlib] [Open] [PROGDIR:mui/BetterString.mcc] [Read] [Fail]
    [134] [ramlib] [Load] [PROGDIR:mui/BetterString.mcc] [] [Fail]
    [135] [ramlib] [Open] [PROGDIR:mui/BetterString.mcc.elf] [Read] [Fail]
    [136] [ramlib] [Open] [PROGDIR:mui/BetterString.mcc.elf] [Read] [Fail]
    [137] [ramlib] [Load] [PROGDIR:mui/BetterString.mcc.elf] [] [Fail]
    [138] [ramlib] [Open] [mui/BetterString.mcc.elf] [Read] [Fail]
    [139] [ramlib] [Open] [mui/BetterString.mcc.elf] [Read] [Fail]
    [140] [ramlib] [Load] [mui/BetterString.mcc.elf] [] [Fail]
    [141] [ramlib] [Open] [PROGDIR:mui/BetterString.mcc] [Read] [Fail]
    [142] [ramlib] [Open] [PROGDIR:mui/BetterString.mcc] [Read] [Fail]
    [143] [ramlib] [Load] [PROGDIR:mui/BetterString.mcc] [] [Fail]
    [144] [ramlib] [Open] [mui/BetterString.mcc] [Read] [Fail]
    [145] [ramlib] [Open] [mui/BetterString.mcc] [Read] [Fail]
    [146] [ramlib] [Load] [mui/BetterString.mcc] [] [Fail]
    [147] [ramlib] [Open] [PROGDIR:libs/amplifierplugin.library.elf] [Read] [Fail]
    [148] [ramlib] [Open] [PROGDIR:libs/amplifierplugin.library.elf] [Read] [Fail]
    [149] [ramlib] [Load] [PROGDIR:libs/amplifierplugin.library.elf] [] [Fail]
    [150] [ramlib] [Open] [MOSSYS:LIBS/xpkmaster.library.elf] [Read] [Fail]
    [151] [ramlib] [Open] [MOSSYS:LIBS/xpkmaster.library.elf] [Read] [Fail]
    [152] [ramlib] [Load] [MOSSYS:LIBS/xpkmaster.library.elf] [] [Fail]
    [153] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc.elf] [Read] [Fail]
    [154] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc.elf] [Read] [Fail]
    [155] [ramlib] [Load] [MOSSYS:LIBS/NList.mcc.elf] [] [Fail]
    [156] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc] [Read] [Fail]
    [157] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc] [Read] [Fail]
    [158] [ramlib] [Load] [MOSSYS:LIBS/NList.mcc] [] [Fail]
    [159] [ramlib] [Open] [LIBS:NList.mcc.elf] [Read] [Fail]
    [160] [ramlib] [Open] [LIBS:NList.mcc.elf] [Read] [Fail]
    [161] [ramlib] [Load] [LIBS:NList.mcc.elf] [] [Fail]
    [162] [ramlib] [Open] [NList.mcc.elf] [Read] [Fail]
    [163] [ramlib] [Open] [NList.mcc.elf] [Read] [Fail]
    [164] [ramlib] [Load] [NList.mcc.elf] [] [Fail]
    [165] [ramlib] [Open] [LIBS:NList.mcc] [Read] [Fail]
    [166] [ramlib] [Open] [LIBS:NList.mcc] [Read] [Fail]
    [167] [ramlib] [Load] [LIBS:NList.mcc] [] [Fail]
    [168] [ramlib] [Open] [NList.mcc] [Read] [Fail]
    [169] [ramlib] [Open] [NList.mcc] [Read] [Fail]
    [170] [ramlib] [Load] [NList.mcc] [] [Fail]
    [171] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc.elf] [Read] [Fail]
    [172] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc.elf] [Read] [Fail]
    [173] [ramlib] [Load] [PROGDIR:LIBS/NList.mcc.elf] [] [Fail]
    [174] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc] [Read] [Fail]
    [175] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc] [Read] [Fail]
    [176] [ramlib] [Load] [PROGDIR:LIBS/NList.mcc] [] [Fail]
    [177] [ramlib] [Open] [MOSSYS:LIBS/mui/NList.mcc.elf] [Read] [Fail]
    [178] [ramlib] [Open] [MOSSYS:LIBS/mui/NList.mcc.elf] [Read] [Fail]
    [179] [ramlib] [Load] [MOSSYS:LIBS/mui/NList.mcc.elf] [] [Fail]
    [180] [ramlib] [Open] [MOSSYS:LIBS/mui/NList.mcc] [Read] [Fail]
    [181] [ramlib] [Open] [MOSSYS:LIBS/mui/NList.mcc] [Read] [Fail]
    [182] [ramlib] [Load] [MOSSYS:LIBS/mui/NList.mcc] [] [Fail]
    [183] [ramlib] [Open] [LIBS:mui/NList.mcc.elf] [Read] [Fail]
    [184] [ramlib] [Open] [LIBS:mui/NList.mcc.elf] [Read] [Fail]
    [185] [ramlib] [Load] [LIBS:mui/NList.mcc.elf] [] [Fail]
    [186] [ramlib] [Open] [mui/NList.mcc.elf] [Read] [Fail]
    [187] [ramlib] [Open] [mui/NList.mcc.elf] [Read] [Fail]
    [188] [ramlib] [Load] [mui/NList.mcc.elf] [] [Fail]
    [189] [ramlib] [Open] [LIBS:mui/NList.mcc] [Read] [Fail]
    [190] [ramlib] [Open] [LIBS:mui/NList.mcc] [Read] [Fail]
    [191] [ramlib] [Load] [LIBS:mui/NList.mcc] [] [Fail]
    [192] [ramlib] [Open] [mui/NList.mcc] [Read] [Fail]
    [193] [ramlib] [Open] [mui/NList.mcc] [Read] [Fail]
    [194] [ramlib] [Load] [mui/NList.mcc] [] [Fail]
    [195] [ramlib] [Open] [PROGDIR:LIBS/mui/NList.mcc.elf] [Read] [Fail]
    [196] [ramlib] [Open] [PROGDIR:LIBS/mui/NList.mcc.elf] [Read] [Fail]
    [197] [ramlib] [Load] [PROGDIR:LIBS/mui/NList.mcc.elf] [] [Fail]
    [198] [ramlib] [Open] [PROGDIR:LIBS/mui/NList.mcc] [Read] [Fail]
    [199] [ramlib] [Open] [PROGDIR:LIBS/mui/NList.mcc] [Read] [Fail]
    [200] [ramlib] [Load] [PROGDIR:LIBS/mui/NList.mcc] [] [Fail]
    [201] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc.elf] [Read] [Fail]
    [202] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc.elf] [Read] [Fail]
    [203] [ramlib] [Load] [MOSSYS:LIBS/NList.mcc.elf] [] [Fail]
    [204] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc] [Read] [Fail]
    [205] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc] [Read] [Fail]
    [206] [ramlib] [Load] [MOSSYS:LIBS/NList.mcc] [] [Fail]
    [207] [ramlib] [Open] [LIBS:NList.mcc.elf] [Read] [Fail]
    [208] [ramlib] [Open] [LIBS:NList.mcc.elf] [Read] [Fail]
    [209] [ramlib] [Load] [LIBS:NList.mcc.elf] [] [Fail]
    [210] [ramlib] [Open] [NList.mcc.elf] [Read] [Fail]
    [211] [ramlib] [Open] [NList.mcc.elf] [Read] [Fail]
    [212] [ramlib] [Load] [NList.mcc.elf] [] [Fail]
    [213] [ramlib] [Open] [LIBS:NList.mcc] [Read] [Fail]
    [214] [ramlib] [Open] [LIBS:NList.mcc] [Read] [Fail]
    [215] [ramlib] [Load] [LIBS:NList.mcc] [] [Fail]
    [216] [ramlib] [Open] [NList.mcc] [Read] [Fail]
    [217] [ramlib] [Open] [NList.mcc] [Read] [Fail]
    [218] [ramlib] [Load] [NList.mcc] [] [Fail]
    [219] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc.elf] [Read] [Fail]
    [220] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc.elf] [Read] [Fail]
    [221] [ramlib] [Load] [PROGDIR:LIBS/NList.mcc.elf] [] [Fail]
    [222] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc] [Read] [Fail]
    [223] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc] [Read] [Fail]
    [224] [ramlib] [Load] [PROGDIR:LIBS/NList.mcc] [] [Fail]
    [225] [ramlib] [Open] [PROGDIR:mui/NList.mcc.elf] [Read] [Fail]
    [226] [ramlib] [Open] [PROGDIR:mui/NList.mcc.elf] [Read] [Fail]
    [227] [ramlib] [Load] [PROGDIR:mui/NList.mcc.elf] [] [Fail]
    [228] [ramlib] [Open] [PROGDIR:mui/NList.mcc] [Read] [Fail]
    [229] [ramlib] [Open] [PROGDIR:mui/NList.mcc] [Read] [Fail]
    [230] [ramlib] [Load] [PROGDIR:mui/NList.mcc] [] [Fail]
    [231] [ramlib] [Open] [PROGDIR:mui/NList.mcc.elf] [Read] [Fail]
    [232] [ramlib] [Open] [PROGDIR:mui/NList.mcc.elf] [Read] [Fail]
    [233] [ramlib] [Load] [PROGDIR:mui/NList.mcc.elf] [] [Fail]
    [234] [ramlib] [Open] [mui/NList.mcc.elf] [Read] [Fail]
    [235] [ramlib] [Open] [mui/NList.mcc.elf] [Read] [Fail]
    [236] [ramlib] [Load] [mui/NList.mcc.elf] [] [Fail]
    [237] [ramlib] [Open] [PROGDIR:mui/NList.mcc] [Read] [Fail]
    [238] [ramlib] [Open] [PROGDIR:mui/NList.mcc] [Read] [Fail]
    [239] [ramlib] [Load] [PROGDIR:mui/NList.mcc] [] [Fail]
    [240] [ramlib] [Open] [mui/NList.mcc] [Read] [Fail]
    [241] [ramlib] [Open] [mui/NList.mcc] [Read] [Fail]
    [242] [ramlib] [Load] [mui/NList.mcc] [] [Fail]
    [243] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/wave.active] [Read] [Fail]
    [244] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/soundmon.active] [Read] [Fail]
    [245] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/shoutcast.active] [Read] [Fail]
    [246] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/ptplay.pri] [Read] [Fail]
    [247] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/ptplay.active] [Read] [Fail]
    [248] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/fc.pri] [Read] [Fail]
    [249] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/fc.active] [Read] [Fail]
    [250] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/cdda.pri] [Read] [Fail]
    [251] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/cdda.active] [Read] [Fail]
    [252] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/au.active] [Read] [Fail]
    [253] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/aiff.active] [Read] [Fail]
    [254] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/oggvorbis.active] [Read] [Fail]
    [255] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/oggstream.active] [Read] [Fail]
    [256] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/mpega.active] [Read] [Fail]
    [257] [AmiNetRadio] [Open] [Work:Apps/Players/AmiNetRadio/players/ahx.active] [Read] [Fail]
    [258] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc.elf] [Read] [Fail]
    [259] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc.elf] [Read] [Fail]
    [260] [ramlib] [Load] [MOSSYS:LIBS/NList.mcc.elf] [] [Fail]
    [261] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc] [Read] [Fail]
    [262] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc] [Read] [Fail]
    [263] [ramlib] [Load] [MOSSYS:LIBS/NList.mcc] [] [Fail]
    [264] [ramlib] [Open] [LIBS:NList.mcc.elf] [Read] [Fail]
    [265] [ramlib] [Open] [LIBS:NList.mcc.elf] [Read] [Fail]
    [266] [ramlib] [Load] [LIBS:NList.mcc.elf] [] [Fail]
    [267] [ramlib] [Open] [NList.mcc.elf] [Read] [Fail]
    [268] [ramlib] [Open] [NList.mcc.elf] [Read] [Fail]
    [269] [ramlib] [Load] [NList.mcc.elf] [] [Fail]
    [270] [ramlib] [Open] [LIBS:NList.mcc] [Read] [Fail]
    [271] [ramlib] [Open] [LIBS:NList.mcc] [Read] [Fail]
    [272] [ramlib] [Load] [LIBS:NList.mcc] [] [Fail]
    [273] [ramlib] [Open] [NList.mcc] [Read] [Fail]
    [274] [ramlib] [Open] [NList.mcc] [Read] [Fail]
    [275] [ramlib] [Load] [NList.mcc] [] [Fail]
    [276] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc.elf] [Read] [Fail]
    [277] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc.elf] [Read] [Fail]
    [278] [ramlib] [Load] [PROGDIR:LIBS/NList.mcc.elf] [] [Fail]
    [279] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc] [Read] [Fail]
    [280] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc] [Read] [Fail]
    [281] [ramlib] [Load] [PROGDIR:LIBS/NList.mcc] [] [Fail]
    [282] [ramlib] [Open] [MOSSYS:LIBS/mui/NList.mcc.elf] [Read] [Fail]
    [283] [ramlib] [Open] [MOSSYS:LIBS/mui/NList.mcc.elf] [Read] [Fail]
    [284] [ramlib] [Load] [MOSSYS:LIBS/mui/NList.mcc.elf] [] [Fail]
    [285] [ramlib] [Open] [MOSSYS:LIBS/mui/NList.mcc] [Read] [Fail]
    [286] [ramlib] [Open] [MOSSYS:LIBS/mui/NList.mcc] [Read] [Fail]
    [287] [ramlib] [Load] [MOSSYS:LIBS/mui/NList.mcc] [] [Fail]
    [288] [ramlib] [Open] [LIBS:mui/NList.mcc.elf] [Read] [Fail]
    [289] [ramlib] [Open] [LIBS:mui/NList.mcc.elf] [Read] [Fail]
    [290] [ramlib] [Load] [LIBS:mui/NList.mcc.elf] [] [Fail]
    [291] [ramlib] [Open] [mui/NList.mcc.elf] [Read] [Fail]
    [292] [ramlib] [Open] [mui/NList.mcc.elf] [Read] [Fail]
    [293] [ramlib] [Load] [mui/NList.mcc.elf] [] [Fail]
    [294] [ramlib] [Open] [LIBS:mui/NList.mcc] [Read] [Fail]
    [295] [ramlib] [Open] [LIBS:mui/NList.mcc] [Read] [Fail]
    [296] [ramlib] [Load] [LIBS:mui/NList.mcc] [] [Fail]
    [297] [ramlib] [Open] [mui/NList.mcc] [Read] [Fail]
    [298] [ramlib] [Open] [mui/NList.mcc] [Read] [Fail]
    [299] [ramlib] [Load] [mui/NList.mcc] [] [Fail]
    [300] [ramlib] [Open] [PROGDIR:LIBS/mui/NList.mcc.elf] [Read] [Fail]
    [301] [ramlib] [Open] [PROGDIR:LIBS/mui/NList.mcc.elf] [Read] [Fail]
    [302] [ramlib] [Load] [PROGDIR:LIBS/mui/NList.mcc.elf] [] [Fail]
    [303] [ramlib] [Open] [PROGDIR:LIBS/mui/NList.mcc] [Read] [Fail]
    [304] [ramlib] [Open] [PROGDIR:LIBS/mui/NList.mcc] [Read] [Fail]
    [305] [ramlib] [Load] [PROGDIR:LIBS/mui/NList.mcc] [] [Fail]
    [306] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc.elf] [Read] [Fail]
    [307] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc.elf] [Read] [Fail]
    [308] [ramlib] [Load] [MOSSYS:LIBS/NList.mcc.elf] [] [Fail]
    [309] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc] [Read] [Fail]
    [310] [ramlib] [Open] [MOSSYS:LIBS/NList.mcc] [Read] [Fail]
    [311] [ramlib] [Load] [MOSSYS:LIBS/NList.mcc] [] [Fail]
    [312] [ramlib] [Open] [LIBS:NList.mcc.elf] [Read] [Fail]
    [313] [ramlib] [Open] [LIBS:NList.mcc.elf] [Read] [Fail]
    [314] [ramlib] [Load] [LIBS:NList.mcc.elf] [] [Fail]
    [315] [ramlib] [Open] [NList.mcc.elf] [Read] [Fail]
    [316] [ramlib] [Open] [NList.mcc.elf] [Read] [Fail]
    [317] [ramlib] [Load] [NList.mcc.elf] [] [Fail]
    [318] [ramlib] [Open] [LIBS:NList.mcc] [Read] [Fail]
    [319] [ramlib] [Open] [LIBS:NList.mcc] [Read] [Fail]
    [320] [ramlib] [Load] [LIBS:NList.mcc] [] [Fail]
    [321] [ramlib] [Open] [NList.mcc] [Read] [Fail]
    [322] [ramlib] [Open] [NList.mcc] [Read] [Fail]
    [323] [ramlib] [Load] [NList.mcc] [] [Fail]
    [324] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc.elf] [Read] [Fail]
    [325] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc.elf] [Read] [Fail]
    [326] [ramlib] [Load] [PROGDIR:LIBS/NList.mcc.elf] [] [Fail]
    [327] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc] [Read] [Fail]
    [328] [ramlib] [Open] [PROGDIR:LIBS/NList.mcc] [Read] [Fail]
    [329] [ramlib] [Load] [PROGDIR:LIBS/NList.mcc] [] [Fail]
    [330] [ramlib] [Open] [PROGDIR:mui/NList.mcc.elf] [Read] [Fail]
    [331] [ramlib] [Open] [PROGDIR:mui/NList.mcc.elf] [Read] [Fail]
    [332] [ramlib] [Load] [PROGDIR:mui/NList.mcc.elf] [] [Fail]
    [333] [ramlib] [Open] [PROGDIR:mui/NList.mcc] [Read] [Fail]
    [334] [ramlib] [Open] [PROGDIR:mui/NList.mcc] [Read] [Fail]
    [335] [ramlib] [Load] [PROGDIR:mui/NList.mcc] [] [Fail]
    [336] [ramlib] [Open] [PROGDIR:mui/NList.mcc.elf] [Read] [Fail]
    [337] [ramlib] [Open] [PROGDIR:mui/NList.mcc.elf] [Read] [Fail]
    [338] [ramlib] [Load] [PROGDIR:mui/NList.mcc.elf] [] [Fail]
    [339] [ramlib] [Open] [mui/NList.mcc.elf] [Read] [Fail]
    [340] [ramlib] [Open] [mui/NList.mcc.elf] [Read] [Fail]
    [341] [ramlib] [Load] [mui/NList.mcc.elf] [] [Fail]
    [342] [ramlib] [Open] [PROGDIR:mui/NList.mcc] [Read] [Fail]
    [343] [ramlib] [Open] [PROGDIR:mui/NList.mcc] [Read] [Fail]
    [344] [ramlib] [Load] [PROGDIR:mui/NList.mcc] [] [Fail]
    [345] [ramlib] [Open] [mui/NList.mcc] [Read] [Fail]
    [346] [ramlib] [Open] [mui/NList.mcc] [Read] [Fail]
    [347] [ramlib] [Load] [mui/NList.mcc] [] [Fail]
    [348] [ramlib] [Open] [MOSSYS:LIBS/NListview.mcc.elf] [Read] [Fail]
    [349] [ramlib] [Open] [MOSSYS:LIBS/NListview.mcc.elf] [Read] [Fail]
    [350] [ramlib] [Load] [MOSSYS:LIBS/NListview.mcc.elf] [] [Fail]
    [351] [ramlib] [Open] [MOSSYS:LIBS/NListview.mcc] [Read] [Fail]
    [352] [ramlib] [Open] [MOSSYS:LIBS/NListview.mcc] [Read] [Fail]
    [353] [ramlib] [Load] [MOSSYS:LIBS/NListview.mcc] [] [Fail]
    [354] [ramlib] [Open] [LIBS:NListview.mcc.elf] [Read] [Fail]
    [355] [ramlib] [Open] [LIBS:NListview.mcc.elf] [Read] [Fail]
    [356] [ramlib] [Load] [LIBS:NListview.mcc.elf] [] [Fail]
    [357] [ramlib] [Open] [NListview.mcc.elf] [Read] [Fail]
    [358] [ramlib] [Open] [NListview.mcc.elf] [Read] [Fail]
    [359] [ramlib] [Load] [NListview.mcc.elf] [] [Fail]
    [360] [ramlib] [Open] [LIBS:NListview.mcc] [Read] [Fail]
    [361] [ramlib] [Open] [LIBS:NListview.mcc] [Read] [Fail]
    [362] [ramlib] [Load] [LIBS:NListview.mcc] [] [Fail]
    [363] [ramlib] [Open] [NListview.mcc] [Read] [Fail]
    [364] [ramlib] [Open] [NListview.mcc] [Read] [Fail]
    [365] [ramlib] [Load] [NListview.mcc] [] [Fail]
    [366] [ramlib] [Open] [PROGDIR:LIBS/NListview.mcc.elf] [Read] [Fail]
    [367] [ramlib] [Open] [PROGDIR:LIBS/NListview.mcc.elf] [Read] [Fail]
    [368] [ramlib] [Load] [PROGDIR:LIBS/NListview.mcc.elf] [] [Fail]
    [369] [ramlib] [Open] [PROGDIR:LIBS/NListview.mcc] [Read] [Fail]
    [370] [ramlib] [Open] [PROGDIR:LIBS/NListview.mcc] [Read] [Fail]
    [371] [ramlib] [Load] [PROGDIR:LIBS/NListview.mcc] [] [Fail]
    [372] [ramlib] [Open] [MOSSYS:LIBS/mui/NListview.mcc.elf] [Read] [Fail]
    [373] [ramlib] [Open] [MOSSYS:LIBS/mui/NListview.mcc.elf] [Read] [Fail]
    [374] [ramlib] [Load] [MOSSYS:LIBS/mui/NListview.mcc.elf] [] [Fail]
    [375] [ramlib] [Open] [MOSSYS:LIBS/mui/NListview.mcc] [Read] [Fail]
    [376] [ramlib] [Open] [MOSSYS:LIBS/mui/NListview.mcc] [Read] [Fail]
    [377] [ramlib] [Load] [MOSSYS:LIBS/mui/NListview.mcc] [] [Fail]
    [378] [ramlib] [Open] [LIBS:mui/NListview.mcc.elf] [Read] [Fail]
    [379] [ramlib] [Open] [LIBS:mui/NListview.mcc.elf] [Read] [Fail]
    [380] [ramlib] [Load] [LIBS:mui/NListview.mcc.elf] [] [Fail]
    [381] [ramlib] [Open] [mui/NListview.mcc.elf] [Read] [Fail]
    [382] [ramlib] [Open] [mui/NListview.mcc.elf] [Read] [Fail]
    [383] [ramlib] [Load] [mui/NListview.mcc.elf] [] [Fail]
    [384] [ramlib] [Open] [LIBS:mui/NListview.mcc] [Read] [Fail]
    [385] [ramlib] [Open] [LIBS:mui/NListview.mcc] [Read] [Fail]
    [386] [ramlib] [Load] [LIBS:mui/NListview.mcc] [] [Fail]
    [387] [ramlib] [Open] [mui/NListview.mcc] [Read] [Fail]
    [388] [ramlib] [Open] [mui/NListview.mcc] [Read] [Fail]
    [389] [ramlib] [Load] [mui/NListview.mcc] [] [Fail]
    [390] [ramlib] [Open] [PROGDIR:LIBS/mui/NListview.mcc.elf] [Read] [Fail]
    [391] [ramlib] [Open] [PROGDIR:LIBS/mui/NListview.mcc.elf] [Read] [Fail]
    [392] [ramlib] [Load] [PROGDIR:LIBS/mui/NListview.mcc.elf] [] [Fail]
    [393] [ramlib] [Open] [PROGDIR:LIBS/mui/NListview.mcc] [Read] [Fail]
    [394] [ramlib] [Open] [PROGDIR:LIBS/mui/NListview.mcc] [Read] [Fail]
    [395] [ramlib] [Load] [PROGDIR:LIBS/mui/NListview.mcc] [] [Fail]
    [396] [ramlib] [Open] [MOSSYS:LIBS/NListview.mcc.elf] [Read] [Fail]
    [397] [ramlib] [Open] [MOSSYS:LIBS/NListview.mcc.elf] [Read] [Fail]
    [398] [ramlib] [Load] [MOSSYS:LIBS/NListview.mcc.elf] [] [Fail]
    [399] [ramlib] [Open] [MOSSYS:LIBS/NListview.mcc] [Read] [Fail]
    [400] [ramlib] [Open] [MOSSYS:LIBS/NListview.mcc] [Read] [Fail]
    [401] [ramlib] [Load] [MOSSYS:LIBS/NListview.mcc] [] [Fail]
    [402] [ramlib] [Open] [LIBS:NListview.mcc.elf] [Read] [Fail]
    [403] [ramlib] [Open] [LIBS:NListview.mcc.elf] [Read] [Fail]
    [404] [ramlib] [Load] [LIBS:NListview.mcc.elf] [] [Fail]
    [405] [ramlib] [Open] [NListview.mcc.elf] [Read] [Fail]
    [406] [ramlib] [Open] [NListview.mcc.elf] [Read] [Fail]
    [407] [ramlib] [Load] [NListview.mcc.elf] [] [Fail]
    [408] [ramlib] [Open] [LIBS:NListview.mcc] [Read] [Fail]
    [409] [ramlib] [Open] [LIBS:NListview.mcc] [Read] [Fail]
    [410] [ramlib] [Load] [LIBS:NListview.mcc] [] [Fail]
    [411] [ramlib] [Open] [NListview.mcc] [Read] [Fail]
    [412] [ramlib] [Open] [NListview.mcc] [Read] [Fail]
    [413] [ramlib] [Load] [NListview.mcc] [] [Fail]
    [414] [ramlib] [Open] [PROGDIR:LIBS/NListview.mcc.elf] [Read] [Fail]
    [415] [ramlib] [Open] [PROGDIR:LIBS/NListview.mcc.elf] [Read] [Fail]
    [416] [ramlib] [Load] [PROGDIR:LIBS/NListview.mcc.elf] [] [Fail]
    [417] [ramlib] [Open] [PROGDIR:LIBS/NListview.mcc] [Read] [Fail]
    [418] [ramlib] [Open] [PROGDIR:LIBS/NListview.mcc] [Read] [Fail]
    [419] [ramlib] [Load] [PROGDIR:LIBS/NListview.mcc] [] [Fail]
    [420] [ramlib] [Open] [PROGDIR:mui/NListview.mcc.elf] [Read] [Fail]
    [421] [ramlib] [Open] [PROGDIR:mui/NListview.mcc.elf] [Read] [Fail]
    [422] [ramlib] [Load] [PROGDIR:mui/NListview.mcc.elf] [] [Fail]
    [423] [ramlib] [Open] [PROGDIR:mui/NListview.mcc] [Read] [Fail]
    [424] [ramlib] [Open] [PROGDIR:mui/NListview.mcc] [Read] [Fail]
    [425] [ramlib] [Load] [PROGDIR:mui/NListview.mcc] [] [Fail]
    [426] [ramlib] [Open] [PROGDIR:mui/NListview.mcc.elf] [Read] [Fail]
    [427] [ramlib] [Open] [PROGDIR:mui/NListview.mcc.elf] [Read] [Fail]
    [428] [ramlib] [Load] [PROGDIR:mui/NListview.mcc.elf] [] [Fail]
    [429] [ramlib] [Open] [mui/NListview.mcc.elf] [Read] [Fail]
    [430] [ramlib] [Open] [mui/NListview.mcc.elf] [Read] [Fail]
    [431] [ramlib] [Load] [mui/NListview.mcc.elf] [] [Fail]
    [432] [ramlib] [Open] [PROGDIR:mui/NListview.mcc] [Read] [Fail]
    [433] [ramlib] [Open] [PROGDIR:mui/NListview.mcc] [Read] [Fail]
    [434] [ramlib] [Load] [PROGDIR:mui/NListview.mcc] [] [Fail]
    [435] [ramlib] [Open] [mui/NListview.mcc] [Read] [Fail]
    [436] [ramlib] [Open] [mui/NListview.mcc] [Read] [Fail]
    [437] [ramlib] [Load] [mui/NListview.mcc] [] [Fail]
  • »18.11.11 - 17:13
    connor
    Posts: 650 from 2007/7/29
    there are only fails, so either youdeselected to show the 'OK messages or there are none. In the latter case the logs tells you what is missing: every *.mcc that is listed and cannot be found. So copy them to sys:classes/mui and there you go.
    dreamed at first typing and wrote the wrong path. corrected.
    [ Edited by connor 18.11.2011 - 22:46 ]
  • »18.11.11 - 20:39
    Henes
    Posts: 507 from 2003/6/14
    Extract from the MorphOS.readme file available in the root directory of every MorphOS installation:
    - Q: Where do I put my 3rd party MUI custom classes?
    A: In SYS:Classes/MUI
    [ Edited by Henes 18.11.2011 - 22:42 ]
  • »18.11.11 - 20:40
    connor
    ... where a new (stable) version of AmiNetRadio without the need for these ancient third party libraries would be very much welcomed. ANR was such a good player but not that stable. I always envy OS4 for having TuneNet. Is there any update in the works? The last version is a bit old ans unmodern now.
  • »18.11.11 - 21:00
    Simon
    Posts: 809 from 2008/7/6
    ît made my powermac freeze twice today. So I am not using it anymore. ALso a shame AmigaAmp isn't updated for MorhpOS anymore or am i mistaken.
    I actually want a cdplayer that just works and maybe gets the songinfo and coverart of the internet. Or does that exist already ?
  • »18.11.11 - 21:04
    XDelusion
    I have been using Kmplayer for my music, thought I'd give Aminet Radio another shot to compare.
  • »18.11.11 - 21:22
    Henes
    You can try SongPlayer, Kaya and MPlayer.
  • »18.11.11 - 22:02
    XDelusion
    Kaya?
  • »18.11.11 - 22:21
    Posts: 12543 from 2003/5/22
    > Kaya?
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6938&forum=9&start=13
  • »19.11.11 - 08:12
    boot_wb
    Posts: 874 from 2007/4/9
    @Henes
    Kaya appears not to work anymore:
    A dialog box (Helpfully entitled "Error") appears stating "Problems with AHI settings or AHI busy, change this and come back."
    The singular button is labelled "Seen".
    No other programs are running which are tying up audio resources, and audio works fine through the mac-mini (all audio device units (0-3) and music unit are set to AppleI2S HiFi 16-bit stereo++).
    Kaya control panel appears, however the preferences window does not open (from RMB menu), and whilst music files can be added to the playlist, nothing happens when the 'play' button is pressed. There also seem to be some gui rendering issues as there are several checkboxes which are unlabelled.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »19.11.11 - 17:03
    Jambalah
    Posts: 820 from 2008/3/30
    @Boot_wb:
    I experienced this issue (on Pegasos) and I noticed Kaya only works using Unit 0 as AHI modes or Pegasos audio modes. I couldn't use emu10k modes...
    So you should set this in the preferences but I read you can't open the window prefs...  :-?
    Maybe trying to erase sys:prefs/kaya/kaya.prefs file...?!? Don't know...
    Question: anyone knows if a catalog file exists, since Kaya search for it at launch? tya!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »19.11.11 - 18:18
    Simon
    Wouldn't it be just nice to be able to right click an audiocd's icon and press play ?
  • »21.11.11 - 15:24
    connor
    Would be nice but what does it have to do with XDelusion's not starting ANR? Hopefully he got it working in the meantime. Would be nice to see a newer version of ANR with native lists and some more one day.
  • »21.11.11 - 15:47
    XDelusion
    I did get it working, thanks!
    ...went back to Mplayer. :)
  • »21.11.11 - 17:44
