IceFS problems on macmini
    MorphDelf
    Posts: 274 from 2004/2/20
    Hello. I try to install IceFS on my old EXT partition, but no matter what I do. Yes, I have read the readme. When formating, I end up with an EXT partition all the time.
    I put 0x49434502 in HDconfig, also using Mounter for making a mountlist etc. But nothing.
    Anyone?
  • »19.11.11 - 15:39
    Leif
    Posts: 111 from 2006/5/31
    Look at mountlist created by Mounter. Fix the DosType
    to 0x49434502, Filesystem to L:IceFileSystem.
    2.x Mounter does not recognice IceFS correctly.
  • »19.11.11 - 15:54
    TheMagicM
    Posts: 1218 from 2003/6/17
    yea, I had the same problem.
    my partition name is DH3..
    so I edited devs:DOSDrivers/DH3 and
    *ADDED* (since it wasnt in there)
    FileSystem = L:IceFileSystem
    edited
    DosType = 0x49434502
    Then went to Tools/FSFormat and formatted my partiton. Voila!
  • »20.11.11 - 14:22
