Posts: 874 from 2007/4/9
Did you try to move the screenbar audio slider anyway?
There's a couple of bugs in the module:
1) if the volume is turned down, then the machine rebooted, the slider is shown at the 'maximum' position after a reboot but the volume remains low (moving the slider resets the volume).
2) If there are two screens open showing the screenbar modules, adjusting the volume on one screen does not update the position of the slider on all screens.
www.hullchimneyservices.co.uk
Windows free since 2011!
