(e)audio.device success
    Posts: 2205 from 2003/2/24
    Nigthlong works more or less! :) Even when it's using rtgmaster... Versions 1.0 and 1.1 won't find suiteable screenmodes, but version 1.2 finds and game works! Main character has some wrong colors and it doesn't move as it should be, but I think that doesn't affect to gameplay too much. Otherwise gfx and other things seemed to be ok. I tested 68k version of the game with Peg1&radeon9200se.
    I tested also Bubble Heroes, but only got grey screen. It's using rtgmaster too.. someone really should write rtgmaster replacement, because there are so many great games on Amiga using it. And Napalm should be alone a reason for it ;)
    Tried Wet (Lula) too. It has cgx-support, but for some reason it suggest some mode-id, which wasn't available.. anyone has any idea why?
  • »15.02.05 - 10:57
    Daff
    Posts: 247 from 2003/4/5
    @pOS : thanks, Nemac 4 works now on my Pegasos.
    For Foundation, I remember it was working since MOS 1.3.
    Now with Pegasos 2, Voodoo3 and MOS 1.4.2, it still working.
    My settings in the prefs editor are :
    - Graphics : 640x480 or 800x600 Voodoo screen, rendering options disabled, small graphics
    - Sound And music : Ahi device, CD audio "off".
    - Game Prefs : Requesters "prefer custom".
    - Installation : all the game is installed on HD.
    The executable is Foundation 1.50. I think it works also with 1.51 and others versions 1.40+.
    If you want more info, I can send you my prefs file : daff1 AT wanadoo DOT fr
    http://obligement.free.fr
  • »16.02.05 - 15:39
    defender
    Posts: 249 from 2011/4/24
    Nemac_4 ERROR: timer couldn't open cia resource
    Hi there I just tried to run Nemac 4 on my PowerMac MDD with MOS 2.7 and get this
    ERROR: timer couldn't open cia resource. The Game does Start but I can not open
    any door and the switches flicker really fast. Is there a way around this problem.
    I have not read this fault before, so I hope its just my setup. I run the game from
    Amiga Future CD22.
    Well hope you have a solution thx.
  • »21.10.11 - 06:40
    defender
    :-? (just a test, to see if the topic changes again)
  • »22.10.11 - 11:25
    defender
  • »22.10.11 - 11:27
