Freezing system when displaying some pdfs
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello, has someone had the same problem when displaying some pdfs under morphos?. I begin opening the file perfectly, then in a moment the app seems to be freezed. I can move the pointer, but can't close or iconify the app, thus, not being available to kill the app via scout, so i'm forced to reboot the old way, using the power button.
    Is this a bug in apdf?. Will it be upgraded soon?.
    Thanks in advance!!!
  • »15.10.11 - 12:46
    osco
    Posts: 680 from 2009/10/20
    I max at ten pdf pages. the replies mentioned a settings change. I lived with it as it was :-D
  • »15.10.11 - 12:52
    _ThEcRoW
    Well i was about to edit the message when i read your reply. I was meant that i cannot move the mouse, so no possibilities to recover the system. Its a shame, as i have always viewed pdfs without problem until now.
    Well, seems that i need to boot into osx, sigh.
  • »15.10.11 - 12:55
    Posts: 12558 from 2003/5/22
    As a stopgap you can alway try using OWB to display PDF files:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7363&forum=16&start=10
    This way you won't have to boot into another OS.
  • »15.10.11 - 13:20
    Jambalah
    Posts: 820 from 2008/3/30
    Here APDF gives some troubles when resizing using zoom button and then window resizing gadget. But only with certain pdf files...
    Why?!?
    https://viewer.zoho.com/home.do
    Just in case.....
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »15.10.11 - 13:27
