How to Block Layer ads in OWB ?
    defender
    Posts: 249 from 2011/4/24
    Is there a way to get rid of this *damn* Layer ads showing up every 10 sec. ?
    For example on http://www.otrkeyfinder.com/ (i use this side quite often), every time
    I search for a film I have to wait until the layer pops up and then slowly disappears.
    I know thats the way they supossed to work - but I real don`t want them there.
    The filter funktion does not work here, but maybe someone has written a script
    to block specified layers?
    thank you in regard.
  • »13.09.11 - 17:44
    Ruud
    Posts: 335 from 2009/2/2
    Try adding http://view.binlayer.com/* as a rule to Windows->Content Blocking and set "Deny" option.
    I had a quick test and seems to work.
    [ Edited by Ruud 13.09.2011 - 22:17 ]
  • »13.09.11 - 19:16
    analogkid
    Posts: 709 from 2004/11/3
    These layers are controlled by JS, aren't they? Maybe it's enough to disable JS support in URL settings.
  • »14.09.11 - 10:46
    defender
    @ Ruud
    I tried that before posting here - for me it does not work
    - but -
    @ analogkid
    disabling Javascript did the job  :-D
    Thanx a lot to both of you !!
  • »14.09.11 - 13:03
