Pat Icons
    danwood
    Posts: 95 from 2009/10/5
    Hey, anybody know where I can download the Pat Icons set, links on Morphzone are dead, and could really do with some new icons for my machine. Thanks.
  • »13.09.11 - 17:46
    Posts: 12543 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7915
  • »13.09.11 - 18:19
    danwood
    Ah so I have to email the author? Odd method of distribution?!
  • »13.09.11 - 20:27
    For the IceFoldersDeluxe set it seems so, yes. In order to download the older sets just take the screenshot URL and truncate after the TLD.
  • »13.09.11 - 20:40
    Krashan
    Posts: 1107 from 2003/6/11
    http://morphos-files.net/download/PatIcons
    The main link on MorphOS Files was the link to author's website and it is dead in fact. But, MorphOS Files always stores a local copy of the archive, available via "local mirror" button. This still works.
    As the main link is dead, I will remove it, and make local link the main one.
  • »14.09.11 - 04:32
    > link the main one.
    You could as well just follow the advice I gave to danwood and link to the PatIconsPack v2.5 file located on the author's recent website.
  • »14.09.11 - 06:39
