OWB on G4 Mac Mini flakey?
    TheMagicM
    Posts: 1220 from 2003/6/17
    So yea, I installed 2.7 on a 1.4ghz G4 Mac Mini w/1gb RAM. When I run OWB my screen flickers and the system runs pretty slow. Is it a 2.7 issue or is OWB flakey?
    Also, this "Ultimate" software pack should I download and install it?
    When is the sale price on MOS? Ie. $100 USD?
  • »03.09.11 - 00:57
    TheMagicM
    oh and BTW, good job on 2.7. I broke out my 1.4 MOS backup and tried running some old software, it worked well. All in all, you did a great job. After all these years you're hanging in there.
  • »03.09.11 - 01:02
    Simon
    Posts: 809 from 2008/7/6
    I think it's because you are low on videomemory . Try setting your screen to less colors and see what it does.
  • »03.09.11 - 03:16
    Korni
    Posts: 473 from 2006/2/23
    First, try to disable "enhanced display" (MorphOS Preferences -> Screen). If it doesn't help your screen is probably too big ;). OWB uses vram and MorphOS doesn't support AGP, so if you run out of vmem system chokes.
    You can check your free vmem by enabling Graphicsmemory module or configuring Titlebar to show it (RMB on screenchanging gadget).
    P.S: 16 bit modes suck.
    [ Edited by Korni 03.09.2011 - 10:09 ]
  • »03.09.11 - 06:05
    Posts: 2581 from 2003/2/24
    Pack Ultima should ONLY be installed on a fresh MorphOS2.7 and it will change alot of things in your setup.
    I had it for a short time on this PowerMac and it was nice in having all SW set up for me, but that also included a lot of trash and somehow many broken catalogs (french string here and there).
    So I removed it when I made it my main MorphOS-system (and since I have access to the beta of some package-manager I will probraly never go back).
    Or short, if you only want a limited amount of apps,tools and games installed and know how to do that yourself better stick to that.
    Edit: MorphOS has been on "sale" for quite a while at 111Euro (which will translate rather painfully into american zloty.....).
    [ Edited by Kronos 03.09.2011 - 12:40 ]
  • »03.09.11 - 08:39
    TheMagicM
    thanks for the replies!
    Now to get rid of those stupid eyeballs that follow my mouse pointer.. LOL
    EDIT:
    Yea, I'll register this after about a month of "testing". :) So far I'm pleased.
    [ Edited by TheMagicM 03.09.2011 - 09:42 ]
  • »03.09.11 - 12:41
    Are they in the screenbar ?
    Right-Click the screen-depth gadget go "modules" and disable them.
  • »03.09.11 - 13:18
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Will be agp supported in the future?. Also i don't understand well, since the graphics system on mac minis is agp. You mean memory management?
  • »03.09.11 - 23:53
    Korni
    AGP works in PCI mode now. New drivers were shown at various events, so it will be supported someday.
  • »04.09.11 - 05:17
    Posts: 12572 from 2003/5/22
    Probably to be included in MorphOS 2.8:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7899&forum=10&start=2
  • »04.09.11 - 07:51
    stephen_robinson
    Posts: 746 from 2007/4/22
    Kronos,
    While you're there it may be a good idea to add the Graphics Memory guage, that way you can see if you are running out of Chip Ram graphics Ram.
    The Mini is a nice little machine, but the 32mb of ram on most of the models is a bit of a drawback, hopefully this 'AGP', will make life easier in the future, This is all news to me BTW.
  • »04.09.11 - 13:45
    TheMagicM
    I believe when I installed Ultimate pack that it added quite a few things into the taskbar. One of them was memory usage.
  • »04.09.11 - 21:47
