ICE FS error 45
    Posts: 649 from 2004/4/15
    Hello,
    i am using ICE FS 2.3 since a few weeks now with work partition.
    The IDe harddisk is connected to to internal IDE controller of my Peagsos 2.
    Since a few days ice fs reports the follwing error when starting simple mail:
    LLIO read failed [ide.device:0] byte $61774A000 length $8000 errorcode 45
    My setup:
    blocksize: 4096
    buffer : 128
    max transfer: 0x7fffffff
    mask: 0xffffffff
    any ideas what's going wrong?
  • »16.04.11 - 13:15
    Posts: 12543 from 2003/5/22
    Don't know anything about your error, but just to say there's a new RC version:
    http://www.blubbedev.net/pipermail/icefs_blubbedev.net/2011-April/000068.html
    Maybe this helps?
  • »16.04.11 - 14:15
    Leif
    Posts: 111 from 2006/5/31
    "LLIO read failed [ide.device:0] byte $61774A000 length $8000 errorcode 45"
    What happens when you press [retry] in the requester ?
    If fs continues with no problems then try
    http://blubbedev.net/temp/icefs204rc2.lha which allows
    setting environment variable to make fs automatically retry
    these errors without putting up requesters. Seems this is what
    SFS does.
    I just discovered the icefs2.4 rc1 does not support this option, as
    was documented, will upload the rc2 shortly, must give it some testing first though.
    ICE_AUTORETRYIO
    - Set it to 1..n for number of automatic retries of failed
    io requests, before putting up a requester. Will not come
    into effect until 3 seconds after FS is started. Default
    is 0 automatic retries.
    Try setting it to 1 first, and see if that helps.
    setenv save ICE_AUTORETRYIO 1
    ..and reboot.
    [ Edited by Leif 16.04.2011 - 21:12 ]
  • »16.04.11 - 16:55
    Selecting "Retry" works.
    I will wait for rc2 and have a try it after installing it.
  • »16.04.11 - 17:28
    Leif
    http://blubbedev.net/temp/icefs204rc2.lha is now available.
  • »16.04.11 - 17:51
    I installed version 2.4rc2,.
    Everything seems to be ok so far.
    ICE_AUTORETRYIO is set to 1.
    If ithere are any further io errors in future, i will report them.
    Thx for this quick fix!
  • »17.04.11 - 08:50
    stephen_robinson
    Posts: 746 from 2007/4/22
    Right, I'm having a bit of a trouble with ICEFS 2.6 and ice doctor 1.0
    It keeps coming up.
    If I run Icedoctor I get:
    08/07/2011 [19:37:23] --- Complete scan of DH1:
    Scanning master extent list.. 27568
    recreated extent $18CA5C00
    extent $18CA5C00: wrong extsize $1
    searching for next extent.. 0
    found it.
    free 150, pool 71, file 27346.
    Done.
    Scanning free linkage.. 150
    Done.
    Scanning reuse linkage.. 17
    Done.
    Scanning directory tree and file extents.. 30349
    Entry "cookieCollection.db-journal.2C07" @ $B6E9F6C0 was found too broken
    Directory "<root>.recycled/" has linkage errors and will be rebuilt..
    Rebuilt 4095 entries.
    30215 files, 133 dirs, 0 softlinks, 0 hardfiles, 0 harddirs.
    0 fixes applied.
    Done.
    Searching for orphaned files.. 27568
    turned extent @ $18C5F400 into free
    Rescued 0 orphaned files.
    Done.
    Scanning recycledir.. 4095
    recycledir bytes inconsistency. fixing it.
    recycledir count inconsistency. fixing it.
    Done.
    Updating bitmaps.. 71
    updated bitmap @ $B6E90C40
    Done.
    Cleaning up master extent list.. 14510
    defined extent as free @ $18CA5C00
    It then
    says something like
    rebuilding free linkage 27568
    152 free rebuilt
    Done
    rebuilding reuse linkage 1140
    At which point it freezes and does nothing, does not respond to reboot.
    It's done that the couple of times I tried it, different number each time.
    [ Edited by stephen_robinson 08.07.2011 - 22:00 ]
  • »08.07.11 - 18:51
    Leif
    Hold on, I'll upload a new version of the doctor later today.
  • »09.07.11 - 14:49
    stephen_robinson
    Oopsie, I managed to fix it, well reformatting the hard drive anyway, it seemed to be the 12,000 odd files in Yam inbox it didn't seem to like.
    Sorry, I know I should have waited, but..
  • »09.07.11 - 17:06
    Leif
    Ah well.. :)
    You managed to spur me into fixing some stuff anyway so here is
    IceDoctor 1.1 :-)
  • »09.07.11 - 17:25
    stephen_robinson
    Small point, but the first line in the readme file says IceDoctor 1.0 (2011.05.17), not 1.1.
    I will test it, but IceDoctor 1.0 didn't find any problems with the reformated drive, which wasn't a suprise.
  • »09.07.11 - 17:59
