Diavolo File Size questions.
    matt3
    Posts: 784 from 2004/2/10
    I'm trying to use Diavolo for my backup purposes and I have a few questions:
    1. I'm backing up to a EXT4 format NAS via smbfs, is it possible to write file sizes bigger than 2 gigs?
    2. If #1 is no, is there a way to automate the naming of the sequential files being used for the backup, so the backup doesn't take days (because I have to manually type a new name every 2 gigs).
    Thanks for the help!
    Matt
    [ Edited by matt3 07.07.2011 - 08:14 ]
  • »07.07.11 - 01:02
    Posts: 1521 from 2003/2/24
    I should know but I cant remember :)
    1. IIRC there is no way around 2GB limit. I have to take a look at it again but it probably cant be supported. I added support for new 64bit DOS API long ago because I wanted to work around this limit.... I cant remember much more about it.
    2. AFAIK no... I would have to check it again
  • »07.07.11 - 19:21
