Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
New version of Lua (0.5) stops Sermonatrix from working
rms
# 1
Posts: 606 from 2004/11/27
Hi, I just noticed that here the new 0.5 of Lua stops Sermonatrix from working.
Any idea why?
22.06.11
12:32
Krashan
# 2
MorphOS Developer
Posts: 1107 from 2003/6/11
I've tested new Lua with Sermonatrix 0.4 and it works. Will test with Sermonatrix 0.5 later.
RastPort
22.06.11
12:40
Tcheko
# 3
Posts: 540 from 2003/2/25
@RMS,
If you're using version 0.6 of Sermonatrix, expect it to crash. Consider using 0.5 instead which is more stable.
22.06.11
16:30
