Sound in UAE-mos ?!?
    Posts: 35 from 2003/6/11
    hi
    mos-uae works great here - aside from sound.
    i tried many sound configs - ON :), 16 bit, mono, stereo, buffersize . . . but everytime after delay config calculation, the whole system freezes (mos1.4).
    the uae.elf argument reads like
    -S2, khz, 16 bit etc. .
    any ideas? does sound work for you?
    kind regards
  • »14.12.03 - 21:54
    Posts: 35 from 2003/9/27
    I think I've heard that sound doesn't work in UAE on MOS yet.
  • »14.12.03 - 22:33
    Coder
    Posts: 296 from 2003/3/5
    I have UAE for MOS running with sound but the sound part is crap. It does play but it stops on certain times. Not much you can do about that. A new version is really needed.
    Coder
  • »14.12.03 - 22:47
