Changing an Apps deficon
    danwood
    Posts: 95 from 2009/10/5
    As you can see in the screenshot below, I have the correct icon for Wookiechat in it's application drawer, however when I minimise it on Ambient it just shows a Tool deficon, how can I set this so it shows the correct icon for Wookiechat? (Where it says "New Messages")
    http://i.imgur.com/LbeUK.jpg
  • »28.04.11 - 16:23
    Posts: 3326 from 2003/3/5
    That's something that Wookiechat's author needs to fix himself.
  • »28.04.11 - 16:52
    Tcheko
    Posts: 544 from 2003/2/25
    Or use another IRC client. Sermonatrix for example. ;)
    http://czeko.free.fr/public/Sermonatrix-0.5.lha
  • »28.04.11 - 17:58
    danwood
    shame then as Jahc has left MOS development iirc :(
  • »28.04.11 - 19:12
