SFS 2 question
    vulture
    Posts: 198 from 2008/2/4
    Hello!
    Is there any way to read SFS/02 partitions under MorphOS? I don't mind if it's a hack or dangerous as I won't be storing critical data on that drive anyway, just something that'll let me have a partition bigger than 128gb (as the SFS/00 limit - which, in reality, is even less, about 100gb) and I'll be able to access it from the OS4 side. Thanks in advance!
    EDIT:
    I just saw there was a version for 68k, SFS 2.3 which is nowhere to be found any more(?!?). Anyone has it and is kind enough to send it?
    [ Edited by vulture 05.04.2011 - 21:57 ]
  • »05.04.11 - 16:44
    Posts: 12563 from 2003/5/22
    I think it's SFS 1.279 for m68k you're searching for.
  • »05.04.11 - 17:41
    vulture
    Sadly, sfs 1.279 aka sfs\00 does not support big partitions (>128gb) or big files (>4gb). That's why I'm hunting that sfs2 2.3 version for 68k which - in theory - should work fine. The problem is, there's nowhere to be found :/ But maybe someone here has it stored somewhere from back then?
  • »05.04.11 - 17:48
    From the ReadMe of SFS 1.277:
    "The size of a file is limited to about 4 GB (DOSType 'SFS\0', several TB with DOSType 'SFS\2')."
    "Supports partitions of up to 128 GB (DOSType 'SFS\0', for 'SFS\2' partitions the limit is 1 TB, but it can be more depending on the blocksize, with 32KB/Block it's 64 TB)."
  • »05.04.11 - 18:16
    Posts: 3336 from 2003/3/5
    Use ext.
  • »06.04.11 - 04:29
    vulture
    @Andreas
    hmmmm, I'll try it, but I think I had in the past and didn't work, thx for the heads up :)
    @jacad
    but that's read-only from the OS4 side, am I wrong?
    [ Edited by vulture 06.04.2011 - 09:59 ]
  • »06.04.11 - 04:57
    Posts: 1521 from 2003/2/24
    Big file support in SFS2 wont work. 64bit DOS systems are incompatible in MorphOS and OS4.
  • »06.04.11 - 05:07
    vulture
    ah! I see! I think I had successfully used jxfs under OS4 with big files at some point and I thought I could with sfs2 as well. But I could still use big (>128gb) partitions, right? thx!
    [ Edited by vulture 06.04.2011 - 10:24 ]
  • »06.04.11 - 05:23
    That's too bad. Using OS4's SFS under MorphOS is asking for trouble on the other hand. Use Fat then :)
  • »06.04.11 - 05:49
    dIGIMAN
    Posts: 273 from 2005/11/7
    Well, i never had no problem with SFS2 and it was to only way to use paritions bigger 127GB before icefs appeard.
    I only use it on partitions that have to be that big...
  • »06.04.11 - 12:45
    vulture
    thx all for your help :)
    @digiman
    did you use sfs2 2.3 or as Andreas suggested 1.279 with sfs\02 mask?
  • »06.04.11 - 14:06
    Using 128GB+ partition should be still fine. Large files are not really problem either. It is just that applications can not access files beyond 2GB limit.
  • »06.04.11 - 16:53
    dIGIMAN
    @vulture:
    I am using Jörg Strohmeyer SFS/2 on the partitions which
    require 127gb+
  • »07.04.11 - 08:44
    vulture
    @digiman + itix
    thx both for the info!
  • »07.04.11 - 09:06
