Q2 from Hyperion
    GMKai
    Posts: 256 from 2003/4/7
    I have tried to install Q2, but installer stops before copying basefiles, at 10%.
    Now i wanted to copy by hand, but files are packed and I don't know how to unpack .hpa files.
    What steps does it take to copy the data frow q2-windows-cd?
  • »09.12.03 - 15:25
    td741
    Posts: 224 from 2003/4/2
    The problem is that qtools doesn't work on MOS. I just modified the install script to copy the packed files. The game works with the packed files.
    I could send you my "hacked" install script if you're interested.
    Steph
  • »09.12.03 - 15:55
    Crumb
    Posts: 732 from 2003/2/24
    @td741
    Wouldn't be a good idea to put it in the files section?
  • »09.12.03 - 19:29
    td741
    I did think about it. :P How do you submit something for the files section? :-?
    Steph
  • »09.12.03 - 19:45
    Crumb
    I've got no idea... send a PM to Thargan to see if he can upload it...
  • »10.12.03 - 11:12
