OWB and mobile connections
    pampers
    Posts: 1068 from 2009/2/26
    Hi
    I use mobile connection, on pc under firefox there is some kind of automatic compression of images because of that connection. It can be removed with modify headers plugin.
    I've noticed that this compression is the same under OWB. How can that be turned off?
    MorphOS 3.x
  • »06.02.11 - 12:45
    Piru
    Posts: 619 from 2003/2/24
    Are you sure? Because in order to do that there would need to be some massive proxy somewhere doing re-compression of images on the fly. Opera has this, it's called Opera Turbo.
    Are you perhaps confusing this with HTTP compression? HTTP Compression is certainly desirable, you don't want to turn it off.
  • »06.02.11 - 14:33
  • ASiegel
    Posts: 1397 from 2003/2/15
    @ Piru
    Yes, and this is exactly what is being done. If you would like to know more, feel free to search the internet for "Vodafone compression", just to name one example.
    Some mobile carriers have been using this for a number years now (at least five to six years based on my personal experience). Opera introduced their implementation fairly late, in comparison.
  • »06.02.11 - 15:29
    Piru
    Oh. You learn new things every day :)
    Personally I prefer my connections untouched, which is what we have around here.
    [ Edited by Piru on 2011/2/7 2:36 ]
  • »06.02.11 - 16:18
    pampers
    Piru: other than that stupid compression it's quite ok. I cannot use landline in here as there is always some trouble with that, last time I was 7 days offline and in my business I cannot afford that.
    Anyway - Fab is there any solution for that? :)
    MorphOS 3.x
  • »06.02.11 - 20:53
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Pampers,
    I don't really see how OWB is related here, in fact, except possibly by the user agent. OWB and Curl don't really deal with this kind of compression (except for gzip stuff, as stated previously).
  • »06.02.11 - 21:12
    pampers
    Hmm that's kind of weird then if you can turn that off in firefox by simple plugin. I wonder if that compression is done some kind before connecting to www sites but for example music streaming is ok and downloading files as well..
    MorphOS 3.x
  • »06.02.11 - 21:44
    Piru
    @Fab
    It's not HTTP Compression like I suspected, it's a transparent proxy giving you lower quality jpeg images instead of the originals.
    Some googling revealed that apparently the trick to disable it is to enforce no-cache for Pragma and Cache-Control headers for every request.
    Source: http://mobilesociety.typepad.com/mobile_life/2007/07/deactivating-th.html
    PS. pampers, you could have just linked to the instructions right away, it would have been much more obvious what was going on ;)
    [ Edited by Piru on 2011/2/7 2:48 ]
  • »06.02.11 - 22:43
  • Fab
    Fab
    Ok, that's interesting. I'll see how i can integrate that in a not too ugly way.
  • »06.02.11 - 22:49
    pampers
    Piru, Fab: sorry for my crap explanation, I'm sick from last week and doesn't think straight sometimes ;)
    MorphOS 3.x
  • »07.02.11 - 07:05
    pampers
    Fab, any update on that?
    MorphOS 3.x
  • »05.03.11 - 09:23
  • Fab
    Fab
    Come on IRC, and we'll try something.
  • »06.03.11 - 16:23
