Any chance for...
    kickstart
    Posts: 227 from 2009/4/28
    ... for this on morphos?
    http://aminet.net/package/util/libs/TheMaestrix
  • »28.02.11 - 02:23
    Posts: 3336 from 2003/3/5
    Architecture: m68k-amigaos
    Doesn't it work?
  • »28.02.11 - 07:16
    Posts: 12572 from 2003/5/22
    > Doesn't it work?
    It doesn't.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4282&forum=9
  • »28.02.11 - 07:32
    Why ask here and not the author then?
  • »28.02.11 - 10:07
    Maybe he just wanted to know if it works at all. For this, MorphZone is the proper place I think.
  • »28.02.11 - 11:05
    kickstart
    The autor seems to be focused on os4 and here are some morphos developers, just for question if some day we can use all this os friendly applications that use cia timings.
  • »28.02.11 - 17:03
    Since CIA are not available in MorphOS 2.0 supported computers, the answer is: no.
  • »28.02.11 - 20:44
    This software runs through AHI, it does not use CIAs.
    I don't see why it couldn't be made to work under MorphOS.
  • »01.03.11 - 01:30
    Well... it starts here but I'm not sure what to do next :)
  • »01.03.11 - 03:50
    Posts: 919 from 2004/1/24
    Try to run Octamed SoundStudio and see it crash :)
  • »01.03.11 - 04:45
    Ah but what does hardware banging of OctaMed has to do with the aminet utility the original poster was asking about?
  • »01.03.11 - 05:44
    Well, to some extend it does:
    "Based on Richard Korber's work, The Maestrix emulates the functionality of his
    Maestix MaestroPro API library, but instead works through AHI. Now any tools
    you have which can play using the maestix.library can now be directed through
    AHI. As an example of the possibilites, SoundStudio can use this library, so
    now you can use SoundStudio to play multi-track 16-bit modules through AHI!
    Yes, now all you AmigaOS4 users can play with SoundStudio once again, and
    catch up from where you left off without the need to wait for an OS4 native
    version. It also works with standard 4 tracker modules as well, so you don't
    have to worry about not having CIA timers, Paula hardware, or how SoundStudio
    doesn't directly support AHI. Now it can!".
    The utility wont help against other hardware banging bits of course, but I can see how ppl think this util could magically make OSS work on MorphOS.
  • »01.03.11 - 14:26
    kickstart
    Not this ultil but one for mos yes.
  • »01.03.11 - 20:13
    XDelusion
    Posts: 602 from 2010/10/27
    We could go for this and CamD.
    This for OctaMED S.S.
    and CAMD dor HD-Rec.
    Two Bounties I'd support. :)
  • »01.03.11 - 20:20
    > CAMD
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=1203&forum=10&post_id=72770#72770
  • »01.03.11 - 22:11
    XDelusion
    Yes, I've heard a ton of people say that it works, but HD-Rec says otherwise.
  • »03.03.11 - 03:03
