how to change default icons for CD images in MOrphOS
    XDelusion
    Posts: 602 from 2010/10/27
    I'm having issues with this. Somehow things got screwed up and now my CD icons are Folders.
  • »01.03.11 - 20:15
    MarK
    Posts: 641 from 2004/1/25
    afaik, in past in the directory env:prefs/sys should be a file default_disk.info or something like that, which setups default icons for disks (and others for drawers, projects, tools etc), to make it permanent, copy those icons into env-archive...
    i'm 100% about this under amigaos 3.1... :) can't test now, as my peg isn't nearby...
    bye, MarK.
  • »02.03.11 - 05:02
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    sys:Prefs/Presets/Deficons/def_cd0disk.info (or def_cdxdisk.info to match any cd* unit).
    And more generally, def_<devicename>disk.info.
  • »02.03.11 - 07:03
    MarK
    now that's cool :)
    bye, MarK.
  • »02.03.11 - 09:35
    XDelusion
    I've been using Amiga for years (on and off), and there is so much I don't know, that so many of you out there seem to know like the back of your hand.
    Makes me feel like a slacker! :)
    Thankx!
  • »03.03.11 - 02:48
