Posts: 820 from 2008/3/30
Hi everybody!
Surfing here and there with the amazing OWB, something strange happened:
the first time OWB crashed and a prompt showed this message:
"pure virtual method called" .....
I was downloading some files... What kind of issue provoke this error with crash??
And then: two times it crashed again with a requester titled "Fatal Error" with allocations and crashes when running low on memory. A hit will follow to dump stackframe, and allocated heap memory will be freed."
I have a 1 gb on Pegasos and my memory was 35% in use. I think something created an extreme situation (the fatal error prompt seem to so explaining..). Unless my Peg is showing some becoming older symptom....
Pegasos II 1 ghz
Powermac G5 dual 2.0 ghz
Powerbook G4 1.67 ghz 17
