Automate Defrag during night on we
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi, I'd like to automate the defrag process during the night on week-end. This should be possible for several partitions. Does anyone know how I can setup such?
    I suppose I can use Cybercron to start the process at a given time as I do for my backup process which is done every night automatically at 2 am but how can I start Defrag, chose an partition, defragment, and then next one, etc.
    Thanks for help.
  • »21.01.11 - 03:28
    Korni
    Posts: 473 from 2006/2/23
    Use WaitX (which comes with MorphOS) instead of Cybercron. Defrag doesn't have any CLI or arexx commands so maybe you can try some other defragmenting tools.
    [ Edited by Korni on 2011/1/21 11:16 ]
  • »21.01.11 - 08:15
    Jambalah
    Posts: 820 from 2008/3/30
    You could test Morgoth's SFSCheck.
    Since it is a command you can start it from Shell and allows you to check partitions and\or defragment them or to perform those operations for a whole device, using a lot of options. There are also two example scripts (for check or defrag) but they didn't work for me: command in a shell did it flawless. So I guess it's me, since I tested on the fly...
    But as Korni suggested using a Wait command in a script and then SFScheck command should work (tested:work).
    Edit: looked and briefly tested Cybercron... Nice program, really complete!!
    [ Edited by Jambalah on 2011/1/21 16:14 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »21.01.11 - 13:05
    Posts: 2095 from 2003/6/4
    Well, but how to cron this procedure? May be a fiver for the neighborhood kids? Their little fingers will do better than mine anyway...
  • »21.01.11 - 17:05
