WookieChat and codesets.library
    Posts: 2094 from 2003/6/4
    Well, Wookiechat seems not to like codesets.lirary newer than 6.8, but YAM 2.6 requires codestes.library newer than 6.8. Does anyone has YAM 2.6 and Wokiechat (2.11) running in parallel? And if so, which program versions?
    Happy to hear Tscheko is doing an alternative IRC-client.
  • »18.01.11 - 07:44
    breed
    Posts: 33 from 2004/7/6
    Why not using AmIRC MOS native version?
    Download FroGGui and my tracks here
  • »18.01.11 - 08:21
    No key.
  • »18.01.11 - 08:44
    tboeckel
    Posts: 21 from 2009/10/29
    What is "seems not to like" supposed to mean? Does it crash? Does it misbehave in any way? Or does it only tell you "I don't like this version."?
    Last time I chatted with James he didn't tell about any issues between codesets.lib and WookieChat.
  • »18.01.11 - 09:54
    With codesets.library >6.8 I get only this:
    [12:54:35] [Connect] Versuche zu verbinden mit chat.freenode.net (6667)
    [12:54:35] [Server] Verbunden
    [12:54:35] -card.freenode.net- *** Looking up your hostname...
    [12:54:36] -card.freenode.net- *** Checking Ident
    [12:54:36] -card.freenode.net- *** No Ident response
    [12:54:36] -card.freenode.net- *** Found your hostname
    [12:55:22] [Server] Link: 127.0.0.1 (Connection timed out)
    [12:55:23] [Server] Nicht verbunden
    [12:55:23] [Connect] Versuche zu verbinden mit (6667) Versuche #1
    [12:55:23] [Connect] Keine Verbindung möglich!
    With codesets.library 6.6 (haven't tried 6.7) it connects successfully.
    [ Editiert durch Zylesea an 2011/1/18 12:59 ]
  • »18.01.11 - 09:58
    tboeckel
    Just tried this with YAM 2.7-dev, WookieChat 2.12b2 and codesets.lib 6.12 without any problem on my WinUAE/OS3 setup. Hence, in general it shold work.
    Perhaps you can try to contact James Carroll yourself to give hime some more details: james.carroll.jahc@gmail.com
    I contacted him already and pointed him to this thread, but so far I got no answer yet. Maybe its the wrong time for NZ.
  • »18.01.11 - 13:19
    Posts: 12558 from 2003/5/22
    I doubt he cares much about a problem that might be MorphOS specific or specific to the (obsolete) MorphOS versions of his software.
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=32324&forum=32
  • »18.01.11 - 16:31
    Simon
    Posts: 809 from 2008/7/6
    you can still get a AmIRC key if you get a NETCONNECT 3.1 cdrom from somewhere. Amigakit has them, but they are overpriced in my opinion.
  • »18.01.11 - 17:20
    That key won't work with more recent AmIRC versions.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7537&forum=3&post_id=79107#79107
  • »18.01.11 - 17:34
    Simon
    did work fine on my Efika with morphOS 2.2 ... however I don't remember if I did use the 68k or PPC version
  • »18.01.11 - 17:59
  • mk
    mk
    Posts: 72 from 2004/5/24
    What?
    Last WookieChat for MorphOS (27.01.2010)
    http://wookiechat.amigarevolution.com/wookiechat/beta/Wookie_MOS_2_12b13.lha work very well with codesets.library 6.12 (23.09.2010)!
    Hint:: But never use new Events at WookieChat. 2.12, thies freeze all!
    [ Edited by mk on 2011/1/19 14:01 ]
  • »19.01.11 - 10:54
    [quote]
    What?
    [/quote
    Indeed 2_12 works. I used a 2_11 version which I thought was the most current one. Thanks for pointing me to the newer version.
  • »19.01.11 - 11:18
