Flush libraries and devices manually
    _DaNi_
    Posts: 154 from 2010/5/4
    I will flush some specific libraries and devices but the program "sysflush" flush all and not manually specific libs-devices or i don“t know.
    Any solution or program for do this?
    Thanks to all
  • »13.01.11 - 10:04
    Posts: 918 from 2004/1/24
    For libraries you can use the command "flushlib".
  • »13.01.11 - 10:15
    _DaNi_
    thanks! i flushed some libraries cgxbootpic.library and others, now i have +1mb available on efika :)
    and for flush .mcc mui libs on memory? any app?
  • »13.01.11 - 14:57
    use the same command :)
  • »13.01.11 - 17:28
    Posts: 3326 from 2003/3/5
    Aww, dang. cgxbootpic should have been autoflushed... Going to fix this for 2.8.
  • »13.01.11 - 19:32
    _DaNi_
    i flushed this libraries when ambient start, now i have available 88,34mb free with 1280x1024x24 enhanced display disabled and lowmem activated, the machine is a efika 5k2
    deviceio.library
    ddc.library
    cgxbootpic.library
    version.library
    [ Editado por _DaNi_ el 2011/1/13 23:25 ]
  • »13.01.11 - 21:20
