Extract audio
    maurensen
    Posts: 358 from 2003/10/3
    I'm trying to extract audio from a .flv downloaded from youtube but I'm having some troubles.
    I'm trying to use ffmpeg and mencoder but I'm not able to rip the mp3 of the video.
    With ffmpeg using the -acodec copy out.mp3 i get only garbage sound (the flv sholud be a container am I right?)
    and trying to re-encode with the option
    -acodec libmp3lame
    I get an error message such "codec not supported"...
    No more luck with mencoder...
    Someone know what can I try?
    Thanx in advance
  • »08.01.11 - 12:56
    Jambalah
    Posts: 820 from 2008/3/30
    Try with ffmpeg:
    http://morphos.lukysoft.cz/en/vypis.php?hledat=ffmpeg
    Example:
    ffmpeg -i Sourcevideo.flv -f mp3 ExtractedAudio.mp3
    I tried with V. 0.4.9 pre 1 and it works.
    You tried with ffmpeg.... I noticed only now!  :-D
    I'm a little bit tired....
    [ Edited by Jambalah on 2011/1/8 16:54 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »08.01.11 - 13:42
    maurensen
    Strange behaviour really. I've re-downloaded ffmpeg just to be 100% sure to have the same version.
    with Jambala's command line suggestion -f mp3 out.mp3
    I get this error:
    Unsupported codec (id=0) for input stream #0.1
    with the oprion -acodec copy put.mp3
    I get a corrupted mp3.
    I've tried with no luck several files dowloaded from youtube all correctly played with my Amiga (ahem, mac :-)) via mplayer...
  • »08.01.11 - 16:07
    Posts: 1390 from 2010/1/6
    You may also have a look at this tread, done some days ago....
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7640&forum=9
    mencoder can decode many formats.....
    [ Editiert durch Amigaharry2 an 2011/1/8 19:09 ]
  • »08.01.11 - 16:08
    Posts: 12552 from 2003/5/22
    Just in case someone is not aware:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6901&forum=3&post_id=70939#70939
  • »08.01.11 - 16:26
    maurensen
    Thanx very much to all, the ubiquitus mencoder did it!
    With:
    mencoder "Five Little Monkeys_.flv" -of rawaudio -oac mp3lame -ovc copy -o a.mp3
    I get the audio file correct.
    As Andreas_Wolf pointed out with Fab's reply to the link, seems the mp3lame side of ffmpeg is somewhat broken.
    Nevermind now my gf has many songs to work with babies at school :-)
    Thanx mates!
  • »08.01.11 - 17:11
    pecanK
    Posts: 70 from 2004/11/5
    Hi,try the latest Mplayer release(11.11.2010) . Run Gmplayer,click right mouse button,select "settings" and "preferences". Change audio driver to "pcm" and click "Use". Then load your flv file. video is being played while sound isn't being played but stored to the Mplayer drawer as "audiodump.wav". Then you can convert it to mp3 with Lame...
    pecaN of the Czech PowerPC User Group
  • »08.01.11 - 18:49
    Jambalah
    Thanks for the tips, mates! I didn't read previous thread... Nice solution!!!
    Pegasos II 1 ghz
  • »09.01.11 - 12:52
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi, this is really great and usefull/helpfull info! Thanks very much.
  • »10.01.11 - 03:28
