Posts: 219 from 2010/5/15
I recently dicovered some strange keyboard behaviour. I think it might have come after installing the pack ultimate, but I cant tell for sure that this is it when it happend
The lcommand m does not work anymore to change screens (lcommand n works)
The Alt buttons are also not working as usual, eg in e-uae I normally can quit the emulator by pressing ctrl lalt q. To quit the emulator I now must use ctrl lalt ralt q.
The other e-uae shortcuts seems to work ok, like ctrl lalt r to reset or together with the F1 to insert floppy.
Also the hotkeys for toggle windows (-repeat alt tab) or (-repeat shift alt tab) does not work. Sometimes I can get it to do something if I use both alt buttons in the combination.
SOLVED (almost)
I discovered the wonders of IControl while writing this post :)
So I found that the rommand q was mapped there and caused the disturbance with e-uae
Also I found that the lcommand m mapping was missing the "m", so now thats ok.
But I couldnt find any conflicts with the alt tab combination for cycling windows, so that is still now working here.
I notice that IControl also have options for activating next and previous window, what is the differerence with this and the window next / previous setting in MUI? And can they work together?
