Posts: 960 from 2010/10/28
I have installed DirOpus 5.
Everything is working well and expect to use it a lot instead of Ambient.
I am having one issue:
When I select a background the dopus5 config screen locks up, which can be killed and continue to use dopus 5.
I converted the jpg into an iff and it still locks up.
I used a very small picture thinking it was a size issue but still the same.
I think there might be some os 3.1 library missing or something like that.
Any ideas?
Thanks
