Posts: 974 from 2010/10/28
Hello,
Is there currently a way to mix partition types?
I would like to have windows and amiga partitions on the same external usb backup drive.
If
I make the drive RDB and add a FAT partition then windows 7 cannot see the FAT partition.
If I make the drive MBR then I cannot add a SFS partition.
Goal:
1 partition SFS for amiga backups.
1 partition NTFS/FAT for windows use.
Need amiga to see amiga partition.
Need windows to see windows partition.
Any way to do this?
