Zaphod
    stefkos
    Posts: 97 from 2004/2/4
    Zaphod - quick and dirt hex editor MorphOS port.
    Get it from here http://stefkos.amigazeux.net/zaphod.lha
  • »06.11.10 - 16:59
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    I used Zaphod to hexedit Zaphod itself and change some residual german texts in the "Setting" menu and elsewhere:
    "Textdarstellungsart" --> "Text representation"
    "alle druckbaren Zeichen" --> "all printable characters"
    "nur ASCII-Zeichen" --> "only ASCII chars"
    "nur buchstaben" --> "only letters"
    "alle Zeichen" --> "all chars"
    "ab vier Zeichen" --> "from four characters"
    "Es konnte nicht in das Clipboard geschrieben werden" --> "Could not write into the clipboard"
    "Das Clipboard ist leer" --> "The clipboard is empty"
    "Keine Datei geladen" --> "No file loaded"
    (I don't know German, this is a Google translation with small changes by me.)
  • »06.11.10 - 22:25
    stefkos
    Send me .cd file and i will create proper binary...or do it yourself, archive contain all sources and makefile ready to build app.
  • »07.11.10 - 17:53
    stefkos
    New zaphod under the same url.
  • »08.11.10 - 16:34
    DoctorMorbius_FP
    Ehm...
    You are too fast for my reaction times...
    And you are a better translator, too!
  • »08.11.10 - 17:58
    stefkos
    Naahh..
    Main author fixed most problems i made only morphos port.
    Greetz to Matthias Rustler
  • »08.11.10 - 18:59
    Mazze
    Posts: 20 from 2010/11/6
    I finally have my Morphzone account (I didn't know that I have to activate it). What I wanted to say is: I have already translated the missing strings :hammer:
  • »11.12.10 - 15:25
