OWB delayed page-loading solved :-)
    boot_wb
    Posts: 874 from 2007/4/9
    As posted previously, I had been having problems with slow loading of some pages under OWB, and has previously found a workaround of using stop & refresh to speed up the page loading.
    3) Slow rendering of certain pages (CSS issue?)
    Particularly noticeable on facebook.
    If I navigate to www.facebook.com, the page can take around 35 seconds to display (according to the network activity box, this is whilst loading a couple of css files).
    If, however, I navigate to www.facebook.com, then immediately stop the page from loading, then refresh - the page displays almost instantly.
    Wee-eird, dude!
    I've now solved this problem for my setup, and since others posted similar experiences, I thought my solution may prove useful:
    My network consists of:
    Clients connected to a wireless router.
    The wireless router is connected to a modem-router.
    The modem-router is connected to the internet.
    (Now hear da words of da Lord)
    The modem-router (provided by ISP) has the following config
    (WAN IP ---.---.---.---, LAN IP 192.168.1.254)
    The wirelss router
    (WAN IP 192.168.1.1, LAN IP 192.168.0.1)
    The clients:
    (IP 192.168.0.---)
    When setting up the network under MorphOS (Settings>System>Network) I had basically been lazy, and set both Gateway and DNS to 192.168.0.1.
    Having recently changed the MorphOS network settings to set the DNS as 192.168.1.254 (my modem-router's LAN-side IP address), this has solved all issues for me. (The Gateway obviously remains as 192.168.0.1)
    I would guess it was something to do with slow request forwarding between the routers for certain sites. It seemed to mainly occur on rich-content pages requiring many connections (eg Guardian.co.uk, Facebook.com).
    Whether this solution is specific to my dodgy setup or is helpful to others remains to be seen. Either way - Yay! OWB now flies as it should. :-D
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »08.11.10 - 21:23
