Remote connection from win7 to Morphos
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Is there software to allow you to connect to MorphOS using RDP?
    I know there is an RDP client to connect MorphOS to Win machine but is there vice versa.
    I am trying VNC but won't connect, get a connection was dropped error.
    Anyone got any suggestions?
    THanks
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »01.11.10 - 15:42
    Posts: 3336 from 2003/3/5
    Assuming you installed the MorphOS VNCServer, it all depends on the client you're using on the Windows side. Not all of them work.
  • »01.11.10 - 15:48
  • JJ
    JJ
    Of course server running on MorphOS.
    Using RealVNC on win7
  • »01.11.10 - 16:15
    Divinity
    Posts: 532 from 2009/9/8
    @JJ
    you need to install VNCserver in MorphOS and configure it.
    http://dreamolers.binaryriot.org/vncserver/index.php?func=DOWNLOAD
    in W7 you need a simple VNC client (for exemple realvnc, http://www.realvnc.com/ ) where you'll use the IP of host MorphOS and default port TCP 5900.
    It' s very very very easy.
    (No, RDP server service It's only in Windows host client and server).
    [ Edited by Divinity on 2010/11/1 20:38 ]
  • »01.11.10 - 16:37
  • JJ
    JJ
    yeah done all that.
    do i need to port fwd 5900 on router and in windows firewall ?
  • »01.11.10 - 16:50
  • JJ
    JJ
    added password on MorphOS side, it requests that. Then after a wait I get an connection closed unexpectedly error.
    Anyone any ideas or suggestions
  • »01.11.10 - 17:16
  • JJ
    JJ
    got it working
    selected acpept lan users only, this wasnt set by default
    working now
  • »01.11.10 - 17:27
