Question about E-UAE
    Dougal
    Posts: 77 from 2010/10/22
    I setup E-UAE and it runs properly when i launch it from shell.
    But i tried to setup the X-ADF. I put it in the correct folder and i set the paths properly but whenever i try and click on an ADF file i get " Failed to load Kickstart image kick.rom"
    The paths are correct (as far as i can tell) and i have kick.rom in the roms folder.
    Any help?
    Power Mac G4 1Ghz (Sonnet Encore) 640Mb, ATi Radeon 9000 Pro, USB 2.0
    OS: MorphOS 2.6 (Registered) , Mac OS X Tiger 10.4.11
  • »24.10.10 - 08:40
    jalla
    Posts: 57 from 2004/10/4
    Could you have used a Amiga Forever kickstart rom ? They require a keyfile along in the same directory.
    Not sure how this will act on E-UAE but anyhow, it's worth a try .
    (edit)
    If this is the case you must add this:
    kickstart_key_file = disk:/dir/rom.key
    [ Edited by jalla on 2010/10/24 16:01 ]
    Pegasos II/G4/512MB/Radeon9200
  • »24.10.10 - 09:45
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Where and how did you set the rom path?
    Either in commandline or in config file), make sure to use PROGDIR:roms/kickblah.rom. If you only use a relative path, it will fail depending on the current directory in ambient context.
  • »24.10.10 - 11:14
    Simon
    Posts: 809 from 2008/7/6
    I also tried E-UAE ... doesn't that archive have some kind of docs ? So far I didn't pass the 1.3 kickstartscreen and that's about it.
  • »24.10.10 - 18:29
    magnetic
    Posts: 2129 from 2003/3/1
    This is why from time to time threads like this occur clamoring for an all in one automagic install that will allow Morphos users to just double click an icon and launch an app/game.. f.ex an .adf file. Yes, i know you can do it but its way too much configuration for average users.
  • »25.10.10 - 05:21
    Simon
    It's way to difficult to find out for the average user... a simple gui wouldn't be a bad thing.
  • »25.10.10 - 06:09
    Dougal
    And near impossible for new users.
  • »25.10.10 - 06:51
    Simon
    Exactly ...
    [ Edited by Oepabakkes on 2010/10/25 11:58 ]
  • »25.10.10 - 06:57
    pampers
    Posts: 1073 from 2009/2/26
    Come on guys:
    http://translate.google.fr/translate?u=http://obligement.free.fr/articles/integrer_euae_ambient.php&sl=fr&tl=en&hl=fr&ie=UTF-8
    Yesterday I was installing that, took mi about 15 minutes to get adf game running through Ambient..
    MorphOS 3.x
  • »25.10.10 - 09:17
    Simon
    You consider yourself a new and average MorphOS user ?
  • »25.10.10 - 10:01
    jcmarcos
    Posts: 1178 from 2003/3/13
    There's no such average user. All MorphOS users are uber-awesome computer users, at least.
  • »25.10.10 - 10:55
    pampers
    Not really, but if someone is using MorphOS imo he had something to do with Amiga or AmigaOS in past. Meaby I'm wrong but configuring euae is really easy..
    MorphOS 3.x
  • »25.10.10 - 12:05
    Simon
    Everything is easy if you know how to ... there is no (usefull) documentation at all in the archive you can find at morphos-files.net
    Yesterday I download E-uae from OS4 depot because it has documentation ... didn't have time to look into it further but I hope that can make things a little more clear.
  • »25.10.10 - 12:10
  • Fab
    Fab
    There is a bonus/readme.morphos that explains how to configure the filetypes supplied in the archive. This is explained again (and more up-to-date, considering this UAE archive pre-dates MorphOS 2.0) with screenshots in that obligement article.
    And i also supplied useful presets files in conf/ directory for A500/A1200 and Workbench use.
  • »25.10.10 - 12:46
