Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
Low Level Format
Daff
# 1
Posts: 251 from 2003/4/5
How to low lovel format a hard drive under MorphOS 2.x ?
(there is an option on MorphOS 1.x with SCSIConfig, but I havn't found anything with MorphOS 2.x)
http://obligement.free.fr
17.10.10
03:43
Tcheko
# 2
Posts: 544 from 2003/2/25
Hi Daff,
Modern drive don't support low level format (which comes from MFM drives) afaik.
Here is some more information on the subject.
http://freepctech.com/pc/001/007.shtml
You mean formating the whole drive?
17.10.10
04:47
Daff
# 3
Hello Tcheko,
Yes, formating the whole drive (but it's not my intention, I would only know if this option is possible with MorphOS 2.0).
17.10.10
12:44
RSchmidt
# 4
MorphOS Developer
Posts: 12 from 2006/10/30
The scsi lowlevel format isn't available anymore as it's not supported by the scsi/ide emulation. If somebody has problems with his ide drive I would suggest using the pc tools of the vendor to check them.
17.10.10
13:28
