mplayer gui missing it's buttons
    amiga4001
    Posts: 452 from 2006/11/16
    Just downloaded the latest mplayer and copied it to my boot partition.
    Works ok but I don't get the buttons in the gui window.
    There is only a few empty squares where there should be icons off a cd etc..
    Any suggestions is it missing something?
    Snoopium doesn't see an error.
  • »30.08.10 - 17:49
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    2 possible reasons:
    - You didn't copy the images directory
    - You run the gui with GMPlayer (which has "mplayer" as default tool), and you happen to have another mplayer binary somewhere else (for instance in C:), that is used instead, and since MPlayer expects its images in PROGDIR:, they won't be loaded (unless they're in that other binary directory too).
  • »30.08.10 - 21:44
