mldonkey/mlnet - using it with 'our' browsers
    Henri
    Posts: 73 from 2003/5/14
    If someone wants to use mldonkey/mlnet, without
    starting webservers or such things, it's possible.
    Start mldonkey/mlnet and open a browser and use
    the following URL:
    http://localhost:4080/submit?q=html_mods
    The HTML-mod is changed with that. Mod 0 runs fine
    with IBrowse and AWeb. With Voyager it is a little
    bit shifted, but it is usable.
    If it doesn't work 'on the fly', quit mldonkey/mlnet
    and re-start it.
    Regards
    BTW: Are there any hints, how I could use PPPoE
    without MiamiDx? PPPoE is very unstable here with
    MiamiDx an my Pegasos (After a short time with
    heavy network-load the whole system freezes).
    Happens only with PPPoE, not with MiamiDx at all.
  • »16.11.03 - 09:19
    weiseb
    Posts: 215 from 2003/3/29
    ok 4th try:
    when i try that I get infinite reloads
    but to set html_mods to false manualy in the
    downloads_expert.ini works for me.
  • »16.11.03 - 12:10
    Posts: 35 from 2003/6/11
    hi
    concerning your pppoe problems: i had the same problems over here. you can try switching to another tcpipstack, eg miami, and try different versions of the via_rhine device. if all this does not work for you, you have to buy a router. thats what i did. no more lockups, the machine is much more stable since then!
    kind regards
  • »16.11.03 - 17:29
    Wishmaster
    Posts: 342 from 2003/6/29
    Great Man.
    Thanks for this hint Henri!
    Pegasos PPC
  • »16.11.03 - 20:35
    hi henri
    thanks for the above mentioned hints. with editing the prefs it works - but i only get an html page with some text printed on it,
    a single text field and an "input" button.
    now, how do i actually "USE" the beast?!
    thanks
  • »17.11.03 - 06:46
    Doraemon
    Posts: 137 from 2003/7/1
    I only get infinite reloads, and if I change html_mods to false in downloads_expert.ini manually I get infinite reloads too.
    Any idea?
  • »17.11.03 - 09:23
  • HAK
    Posts: 225 from 2003/2/24
    @ Pippi,
    When starting, the upper frames aren't fully visible.
    Just drag the frameborder (the line between the upper text field and the lower written text) a little bit down, so you can see the links for working with mldonkey.
    Bye HAK
  • »17.11.03 - 09:29
  • HAK
    @ Doraemon,
    If you set html_mods in downloads_expert.ini to false, you only have to got to http://localhost:4080/
    Bye HAK
  • »17.11.03 - 09:31
    Doraemon
    Wow, It runs fine!
    A lot of thx to all :)
  • »17.11.03 - 10:17
